Home > Technical (L322) > oh no, new key doesn't work |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 |
what I experienced when I tried a flip key with an Ebay shell, is that the transponder seems to work in a particular direction.
7th Nov 2011 11:46pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
when i had a key blank cut he would not accept any returns, he said it will or wont work but if it does not its not his fault, he done it and it worked.. so i think it must be hit and miss in the key cutting world, if i am right the transponder chip is shaped so it will only fit one way, have you tried a little jiggle to see if it will turn, just thinking try taking the transponder out and hold it near the ignition with the old key, find the best place for it to work and then try the new key with the chip in the same place, this will tell you if its the key or not V8 facelift Range Rover Autobiography 22" wheels.
8th Nov 2011 12:01am |
hi FR-RAF did you have the old style key and did you buy a flip key from ebay,if so what did you buy
8th Nov 2011 12:03am |
Hi Dave,
8th Nov 2011 1:04am |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
Tried all sorts of wiggling, there must be one very small bit that's not quite right and it's not letting the barrel turn even though the transponder works perfectly and you can hear the lock disengaging.
8th Nov 2011 9:09pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
You should tell the locksmith if he had done his job properly, you wouldn't have needed to return it...
9th Nov 2011 7:38am |
