![]() | Home > Off Topic > Sky Broadband V others |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
At the moment i have Sky broadband but due to the size of the house there are blindspots that the signal does not reach.
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Of course you can - just buy one and set it up with the same settings as the Sky one. |
You could even use an old laptop or Pc with wireless /wireless adapters to setup an ad-hoc network and then bridge this to the main router! Techie enough?
you still got this problem mick.... i thought you had sorted it out by buying a smaller house.. ... - .- -.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
No Scarey the smaller one is one of the holiday homes |
| ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520
As the others say, get a wireless box to extend the wireless network. I use an Apple Airport Extreme to extend my wireless network (BT main socket is under the stairs) to the two top floors. The coverage it provides (it uses both the 2.4GHz and 5GHz frequencies) and performance are rock solid. Extending your existing wireless network is a piece of |
Problem only restarted Stan as i had two landlines coming into the house one with BT broadband for downstairs and Sky broadband for upstairs , so got shot of the BT one as i wasn't using it to it's proper use .. i.e. telephone calls and such full rental etc etc …
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
I had the same problem Mick.. I went to maplin and bought a planet 150mbps 802.11n wireless range extender. Easy to set up. It basically doubles the reach of your router. £19.99 well spent. You can even plug non wireless devices into it with a patch lead. Previously..
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
Another vote for the Apple airport. Very easy to configure and lots of options. In the end I left the original wireless router, which didn't have much range, as a guest network and set up another wireless network only on apple gear (a Time Machine and Airport). Whereas the original router struggled to get signal except in one room or the room above, the apple kit seems to have better range. |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Apple time capsule (airport and back up device in one box) is great for me, keep my whole house connected.
