![]() | Home > General > diesel warm up |
m10rng Member Since: 19 Aug 2010 Location: london Posts: 64 ![]() ![]() ![]() |
how long do you let your diesel warm up before you start your journey? |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I don't
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Start up and drive off, keeping the revs low and not using full power until the temperature is up. |
I don't but have a 30mph zone for over a mile at the beginning of most journeys so keep the revs low and take it easy. .
Like others have said I always drive steady when engine is cold and keep the revs down. I find if you don't it sounds like a tractor and drinks fuel at an alarming rate. FFRR TD6 HSE
Slight deviation how often should glowplugs be changed if at all? Present :2008 TDV8 HSE
My FFRR has two glow plugs that are faulty, but I'm not going to change them as it starts first turn every time, even in last winters -21c temperatures and I don't wait until they heat up |
Apparently leaving it to run 15-20 min helps the turbo, also helps the oil to loosen up. |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
In the handbook it says to never leave the cold engine to warm up. Creates unnecessary stress on the engine. Same with most manufacturers. |
The idle running with cold engine is nowadays considered to be quite bad (not only for the environment) as it takes a lot longer for the engine to warm up. When the engine is cold all clearances are bigger and therefore wear is marginally higher.
Just always reverse in to where ever you park so that when you return to the car you can get in, get ready and drive straight off.
