Home > Technical (L322) > FLAT BATTERY RR
blench99
United Kingdom 2005 Range Rover Vogue Td6 Java Black
FLAT BATTERY RR
hi, can anybody help me out. my battery keeps going flat on 05 range rover, i've had it tested and its ok. tried disconnecting sat nav & play station- still goes flat . Pulled fuse for radio -still goes flat. I've read on forum's about a relay that can be fitted under centre consul but my local specialist says this is only for earlier RR. I'm at the end of mt teather with this and sick of getting jump leads out. Any ideas ??? please.
Post #93242 18th Nov 2011 9:40pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
FSR?
final stage resistor, do a search, lots on this issue.
Post #93243 18th Nov 2011 9:44pm
PaulB
Double post Whistle
Post #93244 18th Nov 2011 9:44pm
To check for leakage buy yourself one of these
http://www.maplin.co.uk/automotive-current-tester-217879
and then check every fuse on the car for current when the car is shut down.
If you don't find any current leakage on a fused circuit you then need to check for leakage by disconnecting the battery earth, connecting an ammeter to the earth lead and the other side of the ammeter to the car body earth point. Can be done with a multimeter with a current read facility.
If all this proves -ve, could possibly be a failing alternator diode allowing battery drain thro the alternator. This will eventually show a a red non charge light on the dash.
The chances are your battery simply isn't being charged sufficiently to keep up with demand and is permanently in a low state of charge.
To overcome this and charge the battery fully buy yourself a CTECK MSX 7.0 battery charger and your problems may disappear forever.
Post #93247 18th Nov 2011 10:14pm
How old is the battery?
Does it go flat overnight, or in a few hours?
Does it go flat on its own? (Disconnect overnight to test)
Does it only go flat when at home or at other locations too? (could be some wireless activity keeping the car "awake")
Any other mods with electrics to the car apart from PS1/2 ? .
Post #93251 18th Nov 2011 10:43pm
blench99
thanks for the quick replies, first of all i've done a check with amp meter & removed each fuse to see if there is a drain but found nothing.Not sure how old battery is, battery goes flat overnight but sometimes can go flat when parked up after travelling 20 miles, all locations . Never tried disconnecting battery overnight yet but will try it this weekend. many thanks
Post #93257 18th Nov 2011 11:05pm
blench99
sorry i forgot , no other mods with electrics.
Post #93258 18th Nov 2011 11:06pm
Really sounds like duff battery, and given it has gone flat several times it won't be in peak condition any more. But worth checking out the alternator before stumping up the (@) £110 for a new battery.
Lots of threads on the forum about where to get new battery from Smile .
Post #93263 18th Nov 2011 11:33pm
TugRR
Had the same with mine as soon as it became colder last year. I had the battery replaced by an LR specialist who were very surprised to see the car had it's original battery ('05 car).
For me - new battery - problem solved.
Hope yours is as easy . . . .
Thumbs Up Where do you go after one of these . . . ?
Post #93264 19th Nov 2011 12:04am
arron
its sounds like your battery has a floating cell, theres nothing on the car that can drain a good battery in 20mins.
Post #93265 19th Nov 2011 12:18am
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
had similar. Check what alternator is producing on and off load but my advice would be to change the battery (100Amp min) - LR put a warranty battery in a week after ownership and it never was very good - flat battery every two months or so. Paid for a Bosch one from Costco - she has not missed a beat since. Lock the car overnight too - shuts every module down properly - consider also a battery conditioner - Lidl do a good one every now and then for not much!
Enjoy '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #93298 19th Nov 2011 2:46pm
New Battery.....
Post #93299 19th Nov 2011 3:43pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I reckon it's a dud battery too. However it could be a faulty alternator.
I had a similar problem a few years ago. (admittedly a different car - old style Disco). Battery flat one morning so charged it up and drove around for couple of days with no problem. Then dead battery again in morning. This repeated a few more times. I assumed the alternator was ok as it charged when being driven. So bought a new battery, which ran flat after a few days!
When I walked past my car one night I heard a faint whistle from under the bonnet. Investigation led me to find it was coming from the alternator. Seems like an internal fault was causing it to drain the battery when parked up. A new alternator sorted out the problem. Both batteries were fine after that, I kept one in the boot as a spare for emergency.
The problem seems to have been caused when I jet washed the engine bay. I think water got forced into the internal wiring of the alternator and doing some damage. Lesson to be learnt there. Sad No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #93303 19th Nov 2011 4:20pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
1. What was the drain amp draw when you tested it?
2. Check alternator is charging correctly (13.5v - 14.5v) electrics on. Ie heater, lights, stereo ect and rev to 2000rpm. Range rover td6 54 reg touch screen
Post #94039 23rd Nov 2011 9:58pm
blench99
not sure what the drain was, alternator charging ok. i put new battery on on tuesday and so far so good. Very Happy thanks
Post #94054 23rd Nov 2011 10:51pm
