Home > Technical (L322) > Not starting/battery failure? possible solution!
Dolphinboy
Just had 2 days of hell where my 04 4.4 V8 petrol wouldn't start.
Symptoms: Put the key in ignition and turned to stage 2 and all the interior lights worked, dashboard light come on as normal, steering wheel moved etc. but on pushing through to stage 3 (ignition) there was a resounding clunk and everything stopped, lights off etc.
Checked there was a proper contact between the battery poles (?) and the cables and rings. Same again. Charged the battery..... nothing....
Solution: noticed when I put the negative (Earth) cable back on the battery pole there was a spark and a bit of smoke!! checked all the connections and noticed that on the neg connector where the wire attaches to the ring/connector, the protective sleeve had ridden back up and exposed the wire. Put some electrician's tape on the exposed wire and everything back to normal! started with a lion's roar! So must have been shorting out on the earth/neg pole.
Ps this could have been the source of my earlier problems when driving along, all sorts of warning lights came on etc. (see previous post (Help!!)
[/u]
Post #94369 25th Nov 2011 12:02pm
What was shorting out? If it was the neg cable its supposed to be / already connected to the neg pole? I usually get a spark and a ping of smoke when I reconnect, especially if I don't "go" for it. .
Post #94418 25th Nov 2011 5:03pm
