Home > Technical (L322) > Rear Wiper Washer Jet
mjdronfield
Sorry chaps, I've done a search and read all the posts about taking the rear wiper motor out, and threads on clearing the rear wash wipe jet nozzle, but I can't find the nozzle to clear it out.......
Is it under the wiper arm, near the spring when you lift the wiper from the glass ?
Is it on the bolt base, as it were, where it comes through the glass ?
I assume you can get to it without taking the spoiler off ?
I know it'll be obvious when I go and try and find if for the 5th time..............!!
It's never worked whilst I've had the car, so I don't have any previous idea of where it squirts from.
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #94591 26th Nov 2011 3:09pm
The jet is on the wiper arm at the top where it bolts onto the motor spindle. If you look closely you should be able to see it
Post #94595 26th Nov 2011 3:23pm
mjdronfield
Cheers chap.
I had the wiper down in a position where I'd never be able to see the holes.
I've cleared them out, but every time I get a bit of water through, they block up again.
There's obviously some dirt in the line..........
....more investigation needed........
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #94628 26th Nov 2011 6:40pm
Mark
I've covered this with a few pics a while back. It's prob crap in the NRV and crap in the line running to it due to the blockage.
http://www.fullfatrr.com/forum/topic4806.html?highlight=wiper [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #94643 26th Nov 2011 8:53pm
