Home > Technical (L322) > BMW ULM Bluetooth 54 pin rewire..........
mjdronfield
Does anyone know how to wire the BMW ULM module into the 54 pin connector thats in the boot ?
I touched on this in a post a bit back, but now I've got the car and the wiring is already there.
I was pointed towards a chap L322.com, but his links aren't working in his posts, and he hasn't posted in a while.
Another chap called Noddy appears to have done it, but there are no details of the wiring.
If it has to be rewired, what wss supposed to go on the connector originally ?
.....or where can I get the adapter from ? What is it called ?
Many thanks for helping what seems like my 400 questions in the first week of ownership !!
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #94701 27th Nov 2011 8:40am
comports
HI Mark,
Can't help with the re pinning but this is a god source of info.
http://www.roverupgrades.com/Rover_Bluetoo...tions.html Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #94705 27th Nov 2011 9:41am
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
here are all the partnumbers you will need
http://www.realoem.com/bmw/partgrp.do?mode...&hg=84 2002 td6 vogue, 06 supercharged facelift
Post #94712 27th Nov 2011 12:00pm
Andy
I did rewire mine using a diagram on L322.com. I also got a bit of guidance over the phone from the chap who ran the site. I didn't have any success though- It powered up, but i couldnt get any phone to see it over bluetooth.
I think I had a faulty ULF. I never revisited it as I didn't want to buy a 2nd module. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #94769 27th Nov 2011 7:54pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I also got help from Adam at l322.com and in order to save my sanity got him to order and rewire a new section of loom. The Gen13 ULF I have works fine but never actually bothered wiring in the cradle as I changed phones mid build.....
I probably have the pin outs saved if you want them - send me a pm "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #94835 28th Nov 2011 9:29am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Hi Mark,
If I can find it I will let you know Wink - I worked this out a few years ago for my old 2003 FFRR and I am sure I created a PDF...............somewhere Rolling Eyes
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #94879 28th Nov 2011 1:25pm
CADMunkie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Re: BMW ULM Bluetooth 54 pin rewire..........
Mark
Did you find the joy with this?
I've been looking for that Adam that ran the l322.com site, he looked like a mighty useful chap ...
I'm looking to renew my love of my L322 after investing in a new gearbox... I guess I'm going to stick with it for a while, so looking to do the Bluetooth upgrade...
Can anyone help or advise?
It's a silly question too, but if I do the sat Nav upgrade, will I loose the voice of the old one... The Sat Nav reader in the back has stopped working, but I don't want to lose the old 'voice' of my car.
Help
James
Post #98203 18th Dec 2011 12:14am
mjdronfield
Hi James.
Still wanting to do the Bluetooth mod, but the rewire looks a bit scary.
I too would have liked to be able to buy a "converter loom" or an adapter of some kind for the rear connection.
I still don't know what "should" go on the cable in the boot. Logic dictates that something should go there, without needing a rewire, ie what Land Rover intended originally ?
I'd only had my car about 2 or 3 weeks when I upgraded to Mk4 sat nav, and I'm pretty sure the voice has changed. The Pro's outweigh the Con's though.
So, in essence, I still have what has turned out to be the gerneration 1 of the ULM module, sat in a jiffy bag in my workshop.
This is the "troublesome" ULM unit, but then it only cost me £40.
Thought I'd prove it all works before getting a better unit in the long run.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #98213 18th Dec 2011 10:33am
CADMunkie
Does any one know how to get hold of this fabled Adam dude? Master of the loom, and keeper of the knowledge we seek?
James
Post #98221 18th Dec 2011 2:24pm
Ajay(UK)
Ok finally on an old hard drive I found it Very Happy My Range Rover to BMW Bluetooth ULF Pinout Thumbs Up
I hope this helps!
http://www.fullfatrr.com/gallery/albums/us...Pinout.pdf
Post #99901 31st Dec 2011 12:03pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Hi Andy, just so it’s clear if I change the pin order to that on your PDF, add a ULF/microphone and antenna I should get Bluetooth…..depending on which version ULF I get I guess…………., I don’t have a phone module installed but the wiring is there.
How do the pins or wires come out, is it a case of small long nose pliers, also where do you put the pins/wires that are not required?
Post #99982 31st Dec 2011 11:00pm
