Home > Technical (L322) > PDC Fault
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
PDC Fault
Hi
I have an intermitant problem with the PDC on my VSE.
I have done a search on the forum and from the information I have identified that it is probably the front sensors as the 2 either side of the number plate don't seem to be clicking.
All the posts i have read on PDC problems refer to a continuous tone and flashing LED. I have the continuous tone but no flashing LED.
Does the lack of flashing LED mean that if I replace the 2 front sensors that are not working then the PDC will be fixed or could it mean the ECU is broken?
Thanks
Andy 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #94714 27th Nov 2011 12:58pm
not necessarily ..it could be the wiring or the sensors..its a process of elimination..
Post #94751 27th Nov 2011 6:43pm
Andy_J
Thanks, I will get my multi meter out and check the wiring before I order new sensors 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #94752 27th Nov 2011 6:48pm
