Home > Technical (L322) > Bolts on 22"
CUE99T
Bolts on 22"
So got 22" wheels coming this week and need to know what nuts go on as current 19" will be incorrect....any views?
Do they differ depending on wheel?
Cheers
P all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #94988 28th Nov 2011 11:53pm
rory
I have the same bolts for my 19's and 22's.
Cheers
Rory
Post #94990 29th Nov 2011 12:01am
They differ per manufacturer... Some use OE wheel nuts some use 19mm aftermarket wheel nuts, if they are new wheels they should be supplied with them if they are needed...
Just make sure if they use OE wheel nuts, you use the correct type i.e. black (pre 06) or stainless capped (post 06) as the black ones have a smaller shank and will allow the wheel to slip and can cause damage to alloy wheels.
Craig Thumbs Up
Post #94991 29th Nov 2011 12:12am
CUE99T
cheers boys.........
they are used but almost new.......they are shiny on outside and black inside and look like the stormer wheel design I think.
guess I'll just ask the previous owner and see what he used.
need a slight refurb and 2 tyres so not putting them on straight away. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #94999 29th Nov 2011 12:50am
22" stormers depending on the factory who made them can use 19mm old or new type OE bolts unfortunately...
Craig Thumbs Up
Post #95000 29th Nov 2011 12:56am
CUE99T
No problems Craig, much appreciated.
I will see what colin used on them and take it from there.....it was just a quick post incase there was any obvious mistakes to be made!! Cos trust me I'd make them!! Laughing
Thumbs Up all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #95048 29th Nov 2011 1:04pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Measure the diameter of the bolt holes. Also check if the holes are same diameter all the way through. Some non original wheels have tapered holes which need special bolts. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #95146 29th Nov 2011 6:57pm
CUE99T
I'm lead to believe the original bolts were used on the guys car I am taking them from.
They are just spare now, so we'll see when I get them.
cheers for the replies all. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #95288 30th Nov 2011 11:42am
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
i have had this problem and found my original bolts where 19mm dia and the hole in my new stormers where 22.5mm so i had to get new bolts also had to check if flat face or taper face inside the wheel nut aperture
Post #95393 30th Nov 2011 10:27pm
