Home > General > Serious Misting Up
Page 3 of 3 <123
Never noticed myself stan , Now i will need to catch up to you ... Laughing Laughing
@ Kingpleb ,, i do what you have posted but as i said at the start , when going into the car first thing in the morning it mist's up quite bad and takes about 5/7 mins to clear Thumbs Up ====================================
Post #95643 1st Dec 2011 9:27pm
It's always possible that the refrigerant in the ac isn't up to full capacity due to a small leak in the system. It could still allow the ac to operate and produce partial cooling but the evaporator temperature might not be low enough to cause full dehumidification of the air passing over it.
Could explain why your car is misted internally after a cold night and why it takes a relatively long time to clear first thing even using the ac.
Might be worth getting it checked out.
Post #95648 1st Dec 2011 9:39pm
list of things to go through Mick Smile
1. Clear windows in morning with a microfibre cloth or such like to pull as much moisture off them as possible.
2. once dry give them a dam good clean inside, and then outside (cos cleanign the inside will show the dirt/muck lines on the outside anyway!)
3. pull the pollen filter out and check it over.
4. if still nothing then back to the dealer for investigation, but take before and after photos as well to help prove your point and maybe pop by dealership early one morning and see what the ones on the forecourt are like Very Happy
Post #95649 1st Dec 2011 9:49pm
johnson1
MAX A/C automatically switches air circulation on.
If its really misty, just hit DEFROST and that should sort it Thumbs Up
Post #95659 1st Dec 2011 10:46pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Interestingthread, on start up mine mists up the windscreen and then clears it. This morning it was frosty on the outside so I fired it up and hit the defog, cleared the screen but misted up all the side windows. letters not necessarily in the right order
Post #95750 2nd Dec 2011 3:04pm
Page 3 of 3 <123
