![]() | Home > Technical (L322) > No central locking or electric windows |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
probably the connectors ... |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Hello again folks. I've been trying to suss out this problem, now got the window working but the central locking does not work only on this door. It worked perfectly before i had the card off and i havn't done anything with the lock mechansim. All fuses are ok.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Sounds like a problem with the part of the loom that feeds that area. Did you possibly pinch some cables when you were working on that part of your car, or alternatively a connector has worked loose somewhere along the loom. Sounds too much of a coincidence to me. No longer FF owner but still interested. Present car Jaguar XE
try a battery dis-connect/re-connect...procedure is on the forum.. ... - .- -.
Thanks for the speedy response.
Quick update:
nikbarber Member Since: 16 Dec 2011 Location: Warwick Posts: 36 ![]() ![]() ![]() |
Hu Muffster,
mick79 Member Since: 24 Nov 2012 Location: Hampshire Posts: 42 ![]() ![]() |
Check out my post hope it helps http://www.fullfatrr.com/forum/topic14906.html Owner of a bottomless pit, Sorry i mean range rover l322. |
Thanks for the reply. I tried disconnecting the battery and giving it a good charge. I thought that disconnecting it for a while might reset all of the ECU's. Unfortunately it hasn't, and the faults are still there despite having a fully charged battery. 2005 FFRR Td6 Vogue
Hi mate.
Thanks for the tip - it turned out to be the white connector on the switch pack (C2058) which is the one that connects to the BCU and the central locking motors. Even though the connector was latched shut, it wasn't inserted into the socket all the way. All sorted now! 2005 FFRR Td6 Vogue
Great nice one! |
