Home > Technical (L322) > 7S socket ignition live 2004 TD6
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Hi All
I have genuine towing electrice (supplied by Duckworths).
However, when I plug into the caravan and put the ignition on it blows the fuse in the caravan marked (car)
I have had the caravan tested at my dealer and he said all electrics were fine.
I downloaded a copy of the 7S wiring chart and all seems ok apart from I only have one live ignition feed instead of two! and the permanent live is in place correctly.
I have checked the wiring (done by Landrover) and it seems all correct and fine.
Has anyone else had the same problem? Can anyone advise where the ignition fed live's are aken from?
Because of the fuse popping immediately the ignition is on I can only assume that the second ignition live is in facr going to earth on the car.
Look forward to any assistance
Cheers
Ray Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #96108 4th Dec 2011 5:35pm
The two ignition controlled feeds for the 7S socket are fused individually on the fuseboard in the rear drivers side compartment. Fuses 74 and 76, 15A and 20 A respectively. If you have only one feed chances are one is blown.
It's possible it could have blown in conjunction with the fuse blowing in the caravan.
It's also possible whoever wired the tow sockets on your car got it wrong by putting the wrong wires in the wrong connections.
The only way to find the fault really is to get a multimeter out and check each of the 7S sockets pins for earth and 12V +ve respectively.
As wiring the car tow sockets is a straight forward job with the wiring harness being preformed and simply plugged into the cars provided socket I'd also be inclined to have the caravan wiring double checked, starting at the tow plugs.
As you say you have a 12V +ve wire going direct to earth somewhere.
Post #96283 5th Dec 2011 11:40am
rayc
Hi
Thanks for the reply.
The two ignition feed fuses are in place and intact.
The sockets were wired by Landrover so I can only assume it's correct.
Caravan was taken to the agents (Bailey agent) Saturday and all checked out fine.
The 12S socket has 2 earths. 1 permanent live, 1 iginition live. The reverse light is live and the correct time.
I will get a multimeter and have a proper sort. I tend to agree it sounds as though the relay has been wired incorrectly.
I will keep you updated! Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #96368 5th Dec 2011 8:55pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i had problems with my towing electrics, fuses blowing etc until i fitted a genuine L/R kit for the FFRR. it just plugs into the rear of the car and away you go. you know that all will be well when it is plug and play.
these kits come up on ebay quite often of are not too expensive to buy. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #96563 6th Dec 2011 11:08pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
read this http://homepage.ntlworld.com/mark1968/Towi...WiringInfo - scroll down to the bottom - maybe your car is wired for a pre-1999 caravan or vice-versa?
Post #96598 7th Dec 2011 1:03pm
rayc
Hi
Thanks for all the feedback.
It is a genuine LR kit so plug and play.
Went over the electrics thoroughly both car and caravan.
The only thing I can assume is the caravan battery was so flat it was overloading the fuse.
I charged it up, replaced the fuse and it's now fine.
I didn't know about the cutting out of the electric circuit until I went to my Bailey dealer yesterday asking why all the lights went out when I put the ignition on! Whistle Embarassed
Only been caravanning 20 years and never knew that was standard from 99 on vans! Rolling Eyes
So, all is looking good so far.
Just got to get the tracker checked and then we're sorted! Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #96606 7th Dec 2011 2:12pm
