Home > Maintenance & Mods (L322) > corrosion on the mirror mounts
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
well i finally set about doing the corrosion bubbles on the mirror mounting plate, i took the mirror off the car then stripped it down so all i was left with was the mounting plate on its own. i dont now whats on the plate but after stripping the black paint off theres a rubbery surface on there. it took me 2 hours in the sand blaster to get the damn stuff off, anyhow after i got it back to the bare metal i took it up to get it powder coated satin black, cost me all of a fiver to get done. end result is perfect, got to do the same on the other side now and shes pefect again. oh i took all my outer door handles off aswel and sprayed them java black to match the car and get rid of that shabby paint that landrover put on or should i say temporarily put on. i would put pics on but im not clever enough to know how to do that Big Cry .
http://s854.photobucket.com/albums/ab106/t...ver%20td6/
uploaded an album of pics i have done since i owned it including the latest mirror and handle refurb.[/url]
Post #97788 15th Dec 2011 1:00am
arron
oh yeah, i mastered the art of adding pics, its not a big deal to most people but to me its a right achievement. Laughing
Post #98068 16th Dec 2011 9:20pm
Its great when you first get them working Smile
They look sweet now, how long did removal from the car take?
would nitromors be better for stripping them i wonder?
Ps mean the wing mirrors Very Happy
Post #98073 16th Dec 2011 9:33pm
arron
getting the mirrors off was straight forward, took about half hour to get the mirror off and stripped. i tryied the paint stripper put it didnt touch it, i had to go over the plate first with a copper brush on the grinder then go over with the sand blaster to take any edges off and get the areas that you cant get to with the brush off. took about two hours to get the plate stripped completely but the finished product is well worth the effort. i stripped the passenger side last night and dropped it off at the powder coaters to get covered this morning, so by tomorrow i should have two scab free door mirrors fitted to the rr.
Post #98081 16th Dec 2011 10:05pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
looks easy, I have the same bubble problem on my mirror mount, thinking of doing the same this spring.
Is it an easy job getting the wires out, looks like from your pics you have to remove them from the plug?
Post #98120 17th Dec 2011 7:59am
daveo
can you remove the mirror totally from the mount or does the wiring prevent this, V8 facelift Range Rover Autobiography 22" wheels.
Post #98142 17th Dec 2011 11:37am
arron
you have to remove two wires from the multi plug to get the mirror off, easy job though. take the plastic cover off the bottom and take out the four screw , that seperates the mirror from the mount then theres a little retainer that holds the wires in place to take off. after that you need to take out the two wires from the plug then seperate them from the rest of the wiring, then the fun starts to get all that paint and rubbery stuff off. heres a pic of the finished mirrors.
Post #98192 17th Dec 2011 8:39pm
bigdave1947
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
My mirrors are so much worst than this so I will strip but I might try hyrographic dipping on them to see how it looks
Post #325727 3rd May 2015 1:38pm
