Home > Technical (L322) > Groaning noise from nearside front after starting
swirl80
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I too seem to get this noise on a cold start (or set the car to warm up using the FBH) and thought it was normal until i drove a newer ffrr and that didn't do it at all....
Post #109827 27th Feb 2012 11:18pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
You need to clean the fbh out I had the same noise on mine before it broke at Xmas
Its a build of despots on the glow plug stopping it from staring quickly,
Cleaned mine when I change my fbh ecu
Now there's no sound at all, apart from a mini jet engine starting when standing out side of the car. Laughing RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #109856 28th Feb 2012 8:28am
swirl80
Any threads or links to how or where the FBH is located and how to clean without fooking things up? Got a tendancy to be a bit heavy handed when doing DIY/maintenance and would rather not have to shell out to replace the whole unit cos i broke it! Smile
Bit extreme but is it something that can be done by the dealer under warranty, ie. replace the whole thing?
Post #109860 28th Feb 2012 8:40am
Olders
Many thank JR - this sounds right to me. I can't believe the FBH is designed to sound like that! Moreover, I had a webasto FBH on my sailing boat and it never made a groaning noise like that.
You said you cleaned it and this fixed it - any chance you might be able to give some photos/instructions on how to do this as it seems a number of people have this problem and could benefit from your know how Bow down .
It would make a good Wiki for Martin or one of the other mods to put up there.... Whistle
Many thanks in anticipation! Thumbs Up -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #109876 28th Feb 2012 9:57am
