Home > General > Range rover tdv8 2007 light power steering
Stingclive33
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Hi I have just bought a tdv8 vogue and it has very light power steering, it runs straight and breaks straight but seems very light, has any body else had this happen if so any thoughts about what to do.
Post #100704 7th Jan 2012 10:20pm
check the tyre pressures Thumbs Up ... - .- -.
Post #100706 7th Jan 2012 10:39pm
Stingclive33
I have just had new tyres and brake pad/discs fitted and tyrevpressuresvare spot on, I do have to confess that the previous owner fitted storm 22" wheels/tyres. I no these are looked down on and I might fit some 19" wheels from a previous 2007 RR sport.
Post #100710 7th Jan 2012 10:55pm
swirl80
is it only light at slow speeds?
Post #100715 7th Jan 2012 11:18pm
Variable power steering valves are the normal culprit if steering gets very heavy or very light and not too expensive to fit either...
Craig Thumbs Up
Post #100717 7th Jan 2012 11:23pm
Stingclive33
The steering does get firmer the faster I go and above 50 it feels right. It's dry light when stationary up to 40
Post #100719 7th Jan 2012 11:31pm
Stingclive33
Sorry typo it should read very light
Post #100720 7th Jan 2012 11:34pm
would that be the servotronic valve craig?
i replaced mine due to heavy steering but i didnt know one of the other symptoms could be light steering.. ... - .- -.
Post #100721 7th Jan 2012 11:35pm
Yes Stan, the same on all models i think??? We had one that would go from lock to lock with the flick of a finger... Very odd feeling.
Craig Thumbs Up
Post #100723 7th Jan 2012 11:43pm
so clive, consensus is that your servotronic valve needs replacing..
[craig Thumbs Up] ... - .- -.
Post #100724 7th Jan 2012 11:45pm
Stingclive33
Thanks very much, I will be off to get my servotronic valves replaced, when you mentioned that they (is that two) are not expensive, in what sort of ball park will the cost be in?
Post #100729 7th Jan 2012 11:52pm
Stingclive33
Oh Craig I see you have 22" beasties on yours, I have had every body telling me to take mine off what do you think?
Post #100730 7th Jan 2012 11:55pm
These...
Now i have these...
I love 22's on the FF as they fill the arches properly. Not everyones 'cup o tea' but hay ho...
Craig Thumbs Up
Post #100736 8th Jan 2012 12:10am
Stingclive33
I love the look and will keep mine, although all the negative jibes did make me think my light steering was a result of the 22's, so now I feel much happier thanks to you guys Thumbs Up
Ps I posted the same question on the Land Rover forum and attracted the attention of the retards, with some really aggressive comments.
Post #100741 8th Jan 2012 12:27am
Your welcome... Let us know if its cured...
Craig Thumbs Up
Post #100742 8th Jan 2012 12:29am
