![]() | Home > Maintenance & Mods (L322) > Brake Caliper Overhaul |
duka Member Since: 11 Jan 2011 Location: uk Posts: 147 ![]() ![]() |
Very squeaky brakes again when travelling from stand still to around 35 mph. I'd removed all 4 sets of pads in Oct time, cleaned up the pistons (not corrosion or pitting) & re-coppered greased the back of the pads but it only seems a short term fix.
you think the pads may be 'glazed' ? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Could be, or it might just be crap pads. I fitted new recommended inexpensive pads to my FFRR last summer and they squeal like pigs on a spit. I'm going to buy decent pads and bin the ones I have |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
As already said, most likely to be crap pads. I've been there done it time and time a again thinking "I'll save a few quid and buy the cheaper pads, they cant make that much of a difference" and normally end up with squealing pads.
Cut a diagonal edge off the leading edge of each pad and see if this helps. Also have you tried braking hard from about 50-0 a few times, where safe, and without the abs kicking in to help clear the pads??
Have yet to try the champfer edge, but will do this weekend (the pads are actually LR OEM)
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
duka,
Not sure if pagid do sets but the grey and blue pads are great for normal-medium usage |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
me to i allways use ebc suv extreme pads no noise less dust better stopping but more expensive 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
