Home > Maintenance & Mods (L322) > Parking Camera Goosed
Spunner
2006 Range Rover Vogue SE Supercharged Rimini Red
Hi
My rear parking camera has one on the blink on my 06 SC Anniversary - it was fine then would occasionally go all washed out in white , come back sometimes be a black screen and still comes on sometimes when the planets are aligned - I am sure it is just the eye that is goosed but it seems a original replacement is around £200 which seems steep esp considering you can get IR ones these days - anyone done a swap of the eye with a aftermarket camera - if so care to share how easy it was and where to get the camera that fits?
Thanks
Post #101411 12th Jan 2012 8:13pm
in the wiki, http://www.fullfatrr.com/forum/topic4621.html ... - .- -.
Post #101418 12th Jan 2012 8:22pm
I put a 2010 one with the parking lines in my 06 SC and its brilliant compared to the old grainy camera... Purchased a 2010 rear spoiler with camera from the bay and rewired the plug... Happy days!
Craig Thumbs Up
Post #101443 12th Jan 2012 10:48pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Craig, you are a genius when it comes to mods / upradeds for the FFRR.
What's involved in the retrofit of the 2010 rear spoiler and camera ?
Carl
Post #101630 13th Jan 2012 9:10pm
SupaCharged
2005 Range Rover Autobiography Supercharged Java Black
Problem with that wiki entry is its far to vague , not info for another user to do the same....
Post #101631 13th Jan 2012 9:55pm
carlos50
Its been a while since I read it but isn't it how to fit one to a FFRR that doesn't have one rather than upgrade an existing one?
Post #101633 13th Jan 2012 10:02pm
If you can get hold of a 2010 camera and wiring plug its only a matter of soldering four wires together and fitting the camera and housing either two inches further out on the existing spoiler and fitting a grommet into the original hole or fitting the 2010 roof spoiler...
Craig Thumbs Up
Post #101646 13th Jan 2012 11:15pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Do the cameras usually fail entirely or come and go as mine seems to work probably one in 10 or so reverses and even then is hugely grainy and poor?
Is there a compatability issue with say the 2010 camera depending on the year ie mine is a 2006 VIN Td6 with touch screen satnav and lots of can bus gubbins waiting to go wrong!
T
Post #101730 14th Jan 2012 7:26pm
Mine is a 2006 VSE and had no issue fitting it...
Craig Thumbs Up
Post #101750 14th Jan 2012 10:23pm
swirl80
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
sorry to hijack but how much did the camera and spoiler cost and where did you source it?
Post #101885 15th Jan 2012 11:23pm
T24RES
"Purchased a 2010 rear spoiler with camera from the bay" E-Bay Thumbs Up
Post #101894 15th Jan 2012 11:49pm
RR06SC
United States 2006 Range Rover Supercharged 4.2 SC V8 Adriatic Blue
Finally made up a working replacement for the 2006-2009 cameras that fail. Using new electronics in the unit and adapting them to the old wires. You would need to send me the whole unit, I'd retrofit it all and send it back for a direct swap with original wires. I'll have pictures of the unit and the picture quality in the next few days. I can probably do other years but I only have the 2006 to test with. Just trying to make it cheaper/easier for people to replace these cameras.
Post #269692 8th Jul 2014 4:05pm
i'd have a read here first,
Commercial Posting Rules ... - .- -.
Post #269697 8th Jul 2014 4:34pm
