Home > For Sale & Wanted > Wanted: audio components
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Any of you guys know of a mk3 nav unit (part no YIB500040) for sale and also a bm54 harman becker unit (part no XQC500010) as mine is fecked due to water ingress. I am in the process of stipping the back left quarter out to try and find the leak or leaks. AAAARRRRRGH Big Cry
Post #101969 16th Jan 2012 7:04pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
No, not other than on eBay - I'm after a BM54 to get an aux input but £300+ does seems a lot to pay for a 3.5mm hole!
Post #102349 19th Jan 2012 12:00am
In some places you can pay a lot less for a lot larger Wink
Post #102365 19th Jan 2012 7:59am
The only trouble with buying a second hand BM64 is the unit may be heading for the common output channel failure which they seem susceptible to after a few years. You've then got the £200 repair bill to look forward to.
Is it not possible to have your existing unit repaired and an aux input fitted at the same time?
Post #102379 19th Jan 2012 10:41am
