Home > Technical (L322) > Air leak
daddyg
Scotland 2003 Range Rover HSE 4.4 V8 Epsom Green
Air leak
My 10 year old L322 seems to be leaking air but I can't work out where from. The springs all appear ok and it's not dropping or sitting unevenly but after driving there definitely sounds like a leak when you get out. It's loud enough to hear from quite a bit away and seems to last over an hour after turning off the ignition.
Sounds like it's coming from somewhere on the drivers side about half way along the car.
I thought it's maybe a leak somewhere in the system but I can't locate it and can't understand why it isn't dropping.
Anyone any ideas?
Thanks.
Post #243665 19th Feb 2014 6:34pm
theres an air tank where you say its leaking , maybe one of the connections has come off or the tank is leaking?
stick the FF in off road mode and have a look underneath.
Post #243666 19th Feb 2014 6:42pm
daddyg
Cheers Stan. I'll give it a go in the morning and report back.
Post #243693 19th Feb 2014 9:33pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Can be the connector-ventil under your driver door, look in RSW-Solutions on YouTube, there are the pipes to see, and the advices to dismount the shapes. Goes the car down to the floor, when the one hour time is over? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #243752 20th Feb 2014 7:19am
daddyg
Right. Found the leak and like you say Stan it was the air tank. It appears that mud has got trapped between the bracket for the side step and the tank and has corroded it away. Unfortunately I've made it worse whilst I was poking about.
So I'm now wondering is it worth trying to repair with Devcon or something similair or just sort it and be done.
Easy enough to do myself? And is it safe to drive in the meantime till I get it sorted.
Cheers.
Post #243790 20th Feb 2014 11:25am
daddyg
The weird thing meerbusch is that it isn't losing height. Although we'll see now that I've made it worse!
Post #243791 20th Feb 2014 11:26am
if your poking about didnt exasperate the problem then drive as you did but get it sorted asap..
Post #243793 20th Feb 2014 11:50am
I would think the compressor will be working full time to keep the reservoir with enough air to keep the system going.
I would say get it fixed ASAP to save the compressor. Previously..
Post #243795 20th Feb 2014 11:55am
