![]() | Home > Technical (L322) > rain sensing wipers |
| CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82
Is there something different that needs to happen once the windscreen is replaced? Anything need to be re-set, or should it just start sensing automatically, once you put it into Intermittent? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not L322 4.4 Vogue MY05 - Sold to my brother P38 4.6 HSE MY97 - Regretfully sold |
| jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147
In the US market, there was no "Vogue", only the "HSE".
My windscreen was replaced a month ago. Everything worked as designed. Select Intermittent, wipers make 1 pass, no additional input required. Another interesting wiper feature: On "slow" setting, wipers will actually go to "intermittent" when the vehicle stops moving. I believe on "fast" mode, they will goto "slow" when movement stops. I just use "intermittent" all the time, they speed up as needed, and slow down when appropriate. Jim 2000 NAS HSE 2005 NAS HSE |
| All times are GMT |
