Home > LPG > LPG fitters in East Mids
volores
2005 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi all
decided I really need to get the RR converted to LPG.......anyone any recommendations fo quality installers in the East mids area.......I have found Optimus Motors in Leics - anyone any expereince of them?
cheers
Post #104370 30th Jan 2012 3:25pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I've used these chaps http://www.lpg-cars.co.uk/ to convert my last three RR's. They've always done a super job - neat and tidy and working perfectly. Usually lend out a courtesy car - although it's often something a bit rubbish!
Worth contacting. Worth mentioning: They Quoted me £1800 for a BRC system fully fitted to my 4.4 V8
Post #104372 30th Jan 2012 3:38pm
npikey
Ive used this guy a couple of times as has my Brother, very neat and tidy well fitted system
http://www.google.co.uk/url?sa=t&rct=j...lT-Om9WF7w
Post #104474 30th Jan 2012 11:13pm
Andy
If Birmingham isn't too far away, I can recommend HKL GasPower. Used them a lot when I was a Fork Lift Truck Engineer and they always had decent motors in there being converted. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #104730 31st Jan 2012 11:36pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
JE Engineering in Coventry...
If I could afford it then I would be definitely using them. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #112953 14th Mar 2012 12:24am
mzplcg
Leicester Autogas. 0116 286 2701. Speak to Tony and mention my name (Dom). He does a very good job and doesn't rob you blind.
Post #112962 14th Mar 2012 7:55am
MRT07
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
I searched around to first find the best system to fit into a RR (Prins or BRC). I then wanted someone that knew RR/LR. I found an installer in B'ham that was recommended by my Indi who not only had installed many into RR's & exclusivley installed Prins (authorised Prins installer on Prins UK website) but has had 15yrs + experience with LR/RR's and has a couple of the old ones at his garage that he tinkers with & occasionaly treks across numerous deserts around the world.
He won't budge on price & normally takes 4-5 days working on your car to get it installed to a high standard.
My reasons:
1) Indi Recommended
2) Authorised Prins Installer
3) Knows LR/RR's
4) Local
His contact details are on the Prins website "Autogas Power" (B'ham Region)
http://www.prinsautogasuk.co.uk/Network/ApprovedInstaller.html
Hope this helps you?
Post #113050 14th Mar 2012 5:43pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
UKs no1 installer
http://www.autotech-lpg.co.uk/
did mine 2008 ask for Kevin the owner
they look after the bowler wildcat engines they know they stuff
Post #113182 15th Mar 2012 3:33pm
