![]() | Home > Technical (L322) > Rear passeneger compartment vents blow cold or colder |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1476 ![]() ![]() |
I dont think mine works all that well in hot either to be honest. It also takes a long time to heat up for me. I think its cause its a long pipe, which cools the air a lot so by the time it reaches the vents, its much cooler than when it left the heater matrix. Thus it takes a long time for the vent pipe to heat up.
2003 Vague Member Since: 30 Jan 2012 Location: South Northants Posts: 20 ![]() |
Any more info on this?
Yes, it's certainly loud enough.. ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35681 ![]() ![]() |
the left thumbwheel controls the speed and the right controls the temperature [up for warmer]...the max temp is controlled from the front ... - .- -.
yes, in theory... ... - .- -.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Mine always blows hot and seems to warm up very quickly i would say you have a fault somewhere as what you said it not normal or right onto no6 Range Rover
You may wish to read this
Mine has only ever blown cold air? .
Do i detect a spate of the 'sticky flaps' in the air..... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Trust you to bring the tone of the forum down ![]() ![]() |
On a serious note mine has only a few times blown hot air, most of the time its warm as i guess the circuit extends from the front heat excanger back and thus loses some heat to the front and has less for the rear...
Mine goes from toasty hot to ice cold |
^^ I do try my best!!
The air for the rear comes directly off the heater matrix and the ac evaporator and is simply another air outlet on the very complicated heater / evaporator box.
