Home > Technical (L322) > Heated Seat gets so hot it almost burns the legs
Flashman
I have searched through the other heated seat articles, but cannot find one linking to the issue I have with mine. When switched on it warms up but seems to get too hot to touch, I was wondering if the element has moved too close to the leather, but from the other comments the electrics is wired into the leather.
Is there any way to lessen the heated seat power? (other than the 2 stage button, both settings are too hot after warm up even through thick jeans).
Has anyone else had the same issue?
Note: the seats are the pre facelift ones on an 04/05 car. Tom
Current Drive
Previous Drives
Post #106798 11th Feb 2012 3:20pm
ebajema
Yesterday I was looking at the settings menu of the car (Faultmate software) for Bergxu and I noticed that there is a setting that controls the seat temperature. The seat temp can be set to medium and hot in that menu. It is for the MY02-09 range so yours sits right in the middle of that. If you know anyone with a T4 (dealer) or Faultmate or one of the other systems that allow setting changes you can ask them to check and set the temp medium. MY 2010 5.0 SC Galway green and sand interior!!
Post #106800 11th Feb 2012 3:44pm
Flashman
Nice one, I will look into that, was worried that there was something wrong with it, but if you are in arctic conditions I guess the high setting can be useful through all the clothing layers. Tom
Current Drive
Previous Drives
Post #106802 11th Feb 2012 3:59pm
Only last week i had to change the rear swab on an 04 "54" FFRR as the seat heater had started to catch fire! It had burnt the seat cushion inside the seat! so maybe worth checking further on your car... The affected areas were black and crispy!
Craig Thumbs Up
Post #106844 11th Feb 2012 9:00pm
Flashman
So possibly something serious then, is it fairly straight forward to get access to the seat interior/remove the seat covers? Tom
Current Drive
Previous Drives
Post #106858 11th Feb 2012 10:03pm
