Home > Technical (L322) > A/C Gas Recharge - How many grams for my car ? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 392 |
Those controls are for the front only air con - so 700g is correct for your vehicle.
11th May 2024 6:07pm |
Oh, BTW - Your controls are not just for the blower fan, but will also vary the amount of hot-coolant making it to the rear heat exchanger via an electronically controlled valve in the engine bay.
11th May 2024 6:10pm |
Big E Member Since: 16 Jan 2016 Location: Manchester Posts: 3 |
Hi Jon
11th May 2024 6:33pm |
Also
11th May 2024 6:40pm |
Ah, ok.. my misunderstanding on that button. Thinking about it my earlier L322 had that switch as well and it didn't have 4 zone climate. It's just to stop rear passengers (kids) messing with the heat control / fan speed. I'm 100% certain, you don't have rear air-con. Those pictures were of my 2011 Vogue SE (now gone), so if you had 4 zone climate, you'd definitely have those controls. Put your VIN into the link below, it'll give you the build spec of your car as a huge block of text. Read through it to see if you can find reference to climate zones. https://www.vindecoderz.com/ I think that the blue / red marking on the temp knob just indicate which way to turn for hotter / cooler. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
11th May 2024 7:11pm |
Whilst the 2011 brochure doesn't cover the Westminster, I just checked it, and 4 zone climate was an option on all cars, even the Autobiography.
11th May 2024 7:18pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2795 |
If your AC is not working properly the usual culprit on these models is the compressor and not low refrigerant 2012 TDV8 Vogue (L322) |
11th May 2024 8:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7953 |
Put the front on full hot, put the rear on full cold... if it's icy in the back you have four zone...
12th May 2024 9:48am |
