Home > Maintenance & Mods (L322) > Rear alignment |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2230 |
Gents I cannot get the rear wheels to adjust the toe. The max movement doesnt get it in the green on a hunter system anyone any ideas- wondering if it is the control arms although I replaced them not so long ago. The reason I say this is it is as if the bush has gone |
7th May 2024 3:58am |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 669 |
There are cam type washers on some of the rear suspension arm bolts. Did you mark them & return them to their start position after changing the bushes ?
8th May 2024 9:39pm |
Anglo77 Member Since: 28 Feb 2024 Location: New York Posts: 9 |
@sandyt i had a similar problem and found an easy fix, see thread:
9th May 2024 12:35am |
Thanks all
14th May 2024 8:05am |
