Home > In Car Electronics (L322) > Car phone kit question on my new toy 2007 Vogue |
Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105 |
Hi pal I purchased a new module for my 07 vogue of a member called wigs on ere ! He does a px deal with the existing 1 ! Current tdv8 range vogue 07 |
11th Jan 2012 6:42pm |
CarMan Member Since: 03 Dec 2011 Location: Cotswolds Posts: 105 |
Welcome Chim. I haven't been around here long either but my '06 just has the Nokia in, but the Bluetooth just worked |
11th Jan 2012 6:49pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Hi Chim you should already have BT fitted although it will probably need upgrading by the afore mentioned Wiggs . 2008 MY Supercharged
11th Jan 2012 6:59pm |
chim Member Since: 11 Jan 2012 Location: Ayrshre Posts: 11 |
Strange thing is when I select the phone function it just comes up and tells my there is no phone installed, will have a good read of the instructions tonight RRFF 2007 |
11th Jan 2012 7:00pm |
Search using ur blue tooth on ur phone then pair using code 2121 and it should pair if not do as previous or if phone book doesn't download get a up dated module of wiggs like I had to Current tdv8 range vogue 07 |
11th Jan 2012 7:03pm |
Cheers guys, done the search with my phone and it all worked. Happy bunny RRFF 2007 |
11th Jan 2012 10:12pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6672 |
Welcome along Chim, good to see you took the plunge! Got - 2017 SDV8 Autobiography in Loire Blue
11th Jan 2012 10:26pm |
