Home > Technical (L322) > Park Heater Replacement Remote
welsh19
United Kingdom 2005 Range Rover HSE Td6 Zambezi Silver
Hi,
ive bought a 2005 HSE RR at a dealer and the previous owners did not hand in the remote park heater control,
so ive been scouring the web trying to find one and ive come across this,
Genuine Range Rover sport disc 4 Parked Car , Pre Heat remote new style t91
http://www.ebay.co.uk/itm/290659349234?ssP...1423.l2649
it say's it works on LAND ROVER ,RANGEROVER ,SPORT DISC 4 in the description, but im unsure if it will work on my 2005 model i was wondering if anyone knows...
also do you know where i can find a programming guide for it ive tried search and cant find it unless im using the wrong terminology.
thanks
stephen 2005 RR HSE 2.9 TD6 Auto
Post #102524 19th Jan 2012 11:39pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi welsh19
From what Ive read and heard about pairing remotes to ranges is.
Pull the power fuse which is F59 on your car for at least 10 seconds then replace it and hold down the off button on your remote, this is what I've read some where but don't hold me to it Very Happy .
but if it does work ill get one of those,
have you got the older bigger style T90 like me RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #102526 19th Jan 2012 11:48pm
Renegade2
Welsh19 i would check to make sure that you have the telestart module first as not all 2005 models had it as standard. I have a Vogue but no telestart which i found out after buying a T91 remote!!! So have one here if anyone wants one.
You can tell buy looking in the rear right (drivers side) panel it is behind the fusebox.
Also looking in RAVE the ariel amplifier has a coax cables that goes to the unit and the amplifer is diffrent to the one on the left hand side.
Check in case else you will be dissapointed as i was.
Hope that hepls a little
Post #102529 19th Jan 2012 11:56pm
welsh19
thanks for the reply, i will check tomorrow for what you said to look for, 2005 RR HSE 2.9 TD6 Auto
Post #102531 20th Jan 2012 12:00am
kam100
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I have a 2005/55 Range Rover Vogue SE, have just bought a replacement heater fob, so going to give this a try and see if it works. Anyone else had any experience with this since?
Thanks in advance. Current: 11 Bmw 730Ld SE, RR Vogue SE 2006 3.0TD6, 06 Bentley Continental Flying Spur 6.0 W12.
http://WWW.MHCFINANCE.CO.UK - Vehicle Finance Services.
Kam@Mhasnain.co.uk : 0121 622 8122
MotorServ-UK Solihull & Coventry- Premium Auto Service Centres for Service/Repairs/Mot/Alignment/Tyres and Diagnostics. 0121 733 3387
http://www.motorservuk.com
Post #290453 3rd Nov 2014 3:44pm
kam100
This method of taking the fuse out and putting back in after 10 seconds, then holding the OFF button on the remote works.
My remote parking heater is now operational Very Happy Current: 11 Bmw 730Ld SE, RR Vogue SE 2006 3.0TD6, 06 Bentley Continental Flying Spur 6.0 W12.
Post #291465 7th Nov 2014 8:02pm
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
For reference t91 user manual. There is nothing that can't be fixed with a hammer😜😜
Post #291556 8th Nov 2014 9:27am
Andy
Just make sure the telestart module is not a T60, as the T91 will not pair. I got this info from Webasto themselves.
Post #293547 16th Nov 2014 7:32pm
