Home > General > TD6 Broken down twice. |
Have they checked the in tank filter( if there is one) and if that is the pump thats a tiny bit below pressure i'd maybe go with that or ask for it to go to a local specialist instead of a general garage.
28th Jan 2012 8:42am |
landyash Member Since: 05 Jan 2012 Location: Nottinghamshire Posts: 72 |
Hi Chris, are you sure they have tested the injectors?
28th Jan 2012 8:49am |
just a thought have you fitted a new fuel filter? |
28th Jan 2012 8:50am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
^^^ First thing to check |
28th Jan 2012 10:25am |
The secondary fuel pump is prone to giving problems on the TD6, worth checking it out |
28th Jan 2012 11:02am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3075 |
Check your battery connections! I had exactly this..... wouldn't start at all then whilst driving along, lost all power and engine. Turned out it was a loose connection to the neg pole in the battery dept. Tightened them both up and no probs since! |
28th Jan 2012 11:38am |
boffhead Member Since: 19 Mar 2010 Location: Norwich Posts: 42 |
The secondary pump has been done, so I can rule that out. I haven't discounted the filter, but don't expect this to be the cause of such a sudden failure..... will probably replace anyway as they are only about 15 quid. Likewise the relay is about a fiver so this will also probably just get replaced, but I was trying to avoid blindly changing parts.
28th Jan 2012 11:49am |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
I had a similar issue changed the secondary fuel pump worked fine for a few days then died again turn off turn on worked fine for few days then died again any how this went on for around 2 weeks then 1 day i thouoght i would check fuel pump when i touched the pump the car died restarted touched pump connector car died turned out that when the plug had been removed it had stretched the metal connectors within the plug removed plug cover reset contacts never had another problem again |
28th Jan 2012 5:55pm |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 |
some one else on here had a similar problem a while back, it turned out to be the relay/ connections in the ecu box under the bonnet. |
28th Jan 2012 8:27pm |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 |
Get it booked in at a decent local LR independent and get the RAC to come and collect it. Obviously it's above local garage's capabilities and to be fair to them they won't have Autologic diagnostic or vast experience of LRs like a good indy. It's what I'd do or you'll just end up throwing money at it needlessly. |
30th Jan 2012 8:01pm |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 |
This sounds exactly like what happened to ours and it drove me mad! You need to have a look at the clear pipe coming off the fuel filter to the engine when it's either not starting or stopped, it's easy to do and not messy, if it's got either no fuel in it or lots of air bubbles then I bet it's the pump in the tank, our local Landrover dealer denied their even been such a thing but after changing the secondary pump and the car stopping again after having it back 1 day, they took it back in and called me saying their was such a pump in the tank after me telling them for over a week!! Anyway it's been changed and all fine now, but the symptoms were the same as yours. Hope this helps |
30th Jan 2012 11:19pm |
Problem solved....... apparently. I'm told the fuel pump relay was corroded/burnt. Lets hope this is the end of it.
2nd Feb 2012 6:37am |
Broken down again.......... not a faulty relay then |
6th Feb 2012 12:23pm |
Hate to say I told you but take it to a LR specialist. Been down this road myself albeit with a Merc. Sometimes got to bite the bullet and get a specialist on it whether it be building work, fixing a boiler or fixing a car. Just end up throwing money away using someone with basic knowledge of a lot of different things or manufacturers. |
6th Feb 2012 11:15pm |
