Home > Maintenance & Mods (L322) > how to from 2004 to 2006 to 2010
vnitos
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
i've just gotten a 2004 range rover v8 hse with front upgraded to 2006/7 model. what must all be done if i want to change it to 2010 MY. the upgrade from 2004 - 2006/7 include:
- front bumper
- headlights
- grille
- fenders
- bonnet
will the upgrade to 2010MY require any modifications to the electronics of the car and also again replacement of bumpers, fenders etc
also what to do with rear - is it only the lights and then will i have to change electrics/electronics to get the lights to work
Post #104927 2nd Feb 2012 9:59am
bosch
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
To upgrade from the 2007 front to the 2010 front you will need to change the
- Front 2010 Bumper Brackets
- Front 2010 Headlamps (These will need wiring)
- Front 2010 bumper Top bar
- Front 2010 Front Grille
- Front 2010 Bumper Retainers
- Front 2010 Bumper Reflectors
- Front 2010 Front Fog Lamps
- Front 2010 Front Bumper
- Front 2010 Bumper Inserts
- Front 2010 Toe Eye Cover
- Front 2010 Fog Bezels
- Front 2010 Resistors for Headlamps
- Front 2010 Parking Sensors + Brackets
- Front 2010 Parking Sensor Wiring Loom
Additional Notes
- If you are converting a petrol you will require a new air filter
- The front headlamps will need wiring Range Rover SDV8
Post #104938 2nd Feb 2012 11:31am
pretlove
I believe there's no cutting to do now as all that should already have been done "RANGEISM WILL NOT BE TOLERATED"
Post #104997 2nd Feb 2012 3:54pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi
yes there will be some cutting on the inner side of the wings this time,
best way is to remove the wings completely and use a 3" grinder with a wafer disc
it will be clear to you once the wing is removed and you offer up the new 2010 bumper brackets
If you need any advice on the electrics or body work give me pm and ill give you my number
Its well worth the upgrade RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #105090 2nd Feb 2012 9:04pm
