Home > Maintenance & Mods (L322) > Best replacement jack options to replace scissor jack.
M44K TS
Emperor Mong wrote:
Any recommendations on trolley jack? Ideally low enough to fit under the Aston as well?
I got an Arcan 3t one from Costco for use at home, it's shallow enough to get under low cars but crucially, has just enough lift to get the wheels up off the ground when using it on a FFRR...
 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #107453 15th Feb 2012 12:04am
markdotreed
Ironic this thread has started as I had a puncture on Saturday, scissor jack bent under the weight and I had to use the AA to get me on my way.
Came on this morning to say that I ordered some new tyres (puncture was beyond repair) from Camskill which was recommended here. Brilliant service, arrived the next day.
Now I just need a new jack..... Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #107467 15th Feb 2012 9:45am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
That Arcan one is just the ticket. Pity there isn't a Costco near me.
They are on ebay for £50 more than the costco price.
Post #107473 15th Feb 2012 10:29am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
So what is the minimum height required for a jack to just about lifting the car and the wheel off the road?
I looked through the driver manual but it does not seem to list the height from ground to car on extended mode. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #107532 15th Feb 2012 6:32pm
Emperor Mong
That Arcan one above lifts 19-22" according to the ebay ads
Post #107536 15th Feb 2012 7:12pm
farrellelion
Portugal 2002 Range Rover Vogue Td6 Java Black
As the RR scissor jack stows easily in the boot, I would like to keep mine in it's place. Would it be possible , worthwhile, to remove and weld thicker sections in place of the weaker struts? Any idea of what thickness the replacement arms should be? Where does the metal usually fold- I presume always in the same place ?
Is this a problem with the RR Classic too? The Classic weighs 2750 kilos and the L322 ,2002 TD6 weighs in at 3050kilo. 2002 Vogue TD6
2001 Defender 90 TD5
Range Rover Classic 1994
Mercedes Benz 220 S Sedan 1959.
Post #107597 16th Feb 2012 8:54am
markdotreed
Before the L322 Range Rovers had bottle jacks. Scissor jacks were, I guess, a cost cutting exercise Regards
Mark
Post #107602 16th Feb 2012 9:34am
TugRR
. . . . whilst on the subject of jacking - Idea
Have I read on here about a facility to jack the car without the wheel dropping to it's lower suspension limit, so the car would hardly have to be lifted off the ground to change a wheel ?
Or have I made it up !
Thumbs Up Where do you go after one of these . . . ?
Post #107608 16th Feb 2012 11:18am
Emperor Mong
Not sure but I think what I'd do is raise the car on the air suspension, insert jack to touch the jacking point, lower car to access height. Would this cause a problem?
Post #107787 17th Feb 2012 2:31pm
info in rave and in the forum , use the search function... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #107790 17th Feb 2012 2:39pm
