Home > Technical (L322) > Steering Column. Motors and Replacement?
Gents,
Sorry if this is taking up too much space, but following my electrical battery maladies in a recent thread, I've now been told that the solution to the steering column electric motors running after the ignition has been switched off is complete replacement of the column and motors in one lot, totalling £1300!
Now, Guava Land Rover tell me there's no easier or other fix. It's a complete assembly from LR and that's it.
They reckon the ring gear from the column to the motors has gone (common, apparently...) and that's the issue. Nothing else for it, apparently, other than a complete unit changeout. They reckon it's a 90 minute job and a very expensive modularised part. They also tell me individual motors aren't available.
So, may I ask what's your views? Is the above correct?
I've got a warranty on this from Ram and that's being looked into. But my cynicism tells me this could be a big bill for yours truly. Si. <This is my name.
Post #107471 15th Feb 2012 10:14am
here's just a few threads re this problem, hope it helps..
http://www.fullfatrr.com/forum/topic4866.h...lumn+motor
http://www.fullfatrr.com/forum/topic4144.h...ring+colum
http://www.fullfatrr.com/forum/topic6765.h...lumn+motor ... - .- -.
Post #107479 15th Feb 2012 10:43am
Stan, they threw away the mould when they made you. Bow down
Just read all 3 links.
Feel better now, but won't rest until I know what the warranty company say. Si. <This is my name.
Post #107481 15th Feb 2012 11:00am
you're welcome.. Thumbs Up
if you want to attempt it yourself , there's a 'how to' floating about some where on the forum... ... - .- -.
Post #107483 15th Feb 2012 11:09am
Guava have confirmed the problem as above, so it's definitely the steering column and motors.
The warranty on this RR (that came with it) has said this isn't covered. I don't have faith in warranties anyway, so this is no surprise to me. But the warranty company said the problem on this model has been reported before, which is a bit of a shock.
But I like my cars to work as they should, so I've decided to have it replaced and will just have to eat mouldy bread and drink stagnant water for the forseeable future.
At least I get it back tomorrow all working properly.
Glad I didn't buy those new 20" alloys and tyres now. Si. <This is my name.
Post #107494 15th Feb 2012 12:49pm
here's the how to bellini...
http://www.fullfatrr.com/forum/topic5754.h...ing+column
if the steering wheel is or you can get it to the correct position for your drivability then consider a RAC or IIDTool to switch the thing off...cost of these is around £300 'ish and you can use them for other things like switching off errors .. ... - .- -.
Post #107498 15th Feb 2012 2:06pm
