Home > Maintenance & Mods (L322) > How to add LED lights?
M44K TS
You need the interface lead and the software, do a search for Navcoder, there should be plenty of info about it. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #22480 16th Jul 2010 11:29am
thanks Thumbs Up
Post #22491 16th Jul 2010 12:22pm
daveo
hi,i have a interface lead for sale,new used once £20.00 you will need navcoder. V8 facelift Range Rover Autobiography 22" wheels.
Post #22553 16th Jul 2010 10:20pm
dave, unfortunately at the moment i'm still looking for a ffrr but if you still have this cable when i get one then i'll have it of you ..
Post #22585 17th Jul 2010 12:29pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
check out the daytime running lights on this truck, maybe you could remove the foglights and get these to fit ?
http://www.scania.com/media/calendar/2009/...mp;group=1 2002 td6 vogue, 06 supercharged facelift
Post #22617 17th Jul 2010 8:10pm
daveo
i suppose you could always use the cornering lights below the indicator,it has the side light in it as well [if not used like mine] and fit a super bright 9 led bulb there as a daytime running light
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #22618 17th Jul 2010 8:45pm
are these cornering lights standard dave? if not then the fogs are still the best bet me thinks...
Post #22619 17th Jul 2010 9:09pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
M44K TS wrote:
Personally, I find some LED DRL's a bit tacky when they're not supposed to be there, even some OEM ones look a bit odd to me. I much prefer the likes of Mk6 Golf's where they use the main beam dimmed. Incidentally, I went onto Navcoder yesterday and enabled the DRL function on my car, got the main beam on 25% brightness dring the day, then they go off when the headlights come on.
Looked a bit odd at first but I quite like them, might set the brightness to 35% though as they look a little yellow.
Did you try the brighter setting?
Also - as I want to enable DRL what do I need to set a 2003 at for the E module settings or do I just "read" first and it sorts its self in Navcoder? Don't want to enable them and find I've activated the ejector seat by mistake Wink
Post #22817 20th Jul 2010 3:50pm
M44K TS
Haven't tried a brighter setting yet, It's been raining every time I've had a spare 10 mins, sod's law!
If I can dodge the rain later, I'll have a go. As far as Navcoder is concerned, I always click 'read' first, then select the option then 'code' It's simple enough to do though. 2006 Mercedes CLS
Post #22827 20th Jul 2010 5:40pm
DRRS
2011 Range Rover Westminster TDV8 Orkney Grey
Hi, new to forum and new to using forums too!
On the subject of LED's. Does anyone know if the 2012 black surround headlight LED's can be activated to be used as DRL's?
Or am I correct in assuming that the main beam will be activated and not the LEDs when the DRL function is activate
Cheers
Post #110580 2nd Mar 2012 7:53pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Interior/exterior led FFRR s/c 2007
Hi guys
Has anyone bought a bundle of led replacements for a rangey,
eBay is a mine field I'm looking for super bright ones, help.
Thanks
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #110584 2nd Mar 2012 8:15pm
