Home > Maintenance & Mods (L322) > replacement transmission cooler
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
where can I get a replacement transmission cooler from at a fair price ? or can they be flushed \?
Post #113259 15th Mar 2012 9:34pm
If it's not leaking they can be cleaned
Post #113263 15th Mar 2012 10:02pm
Might be better to change it pal, we have to change them when we fit recon gearboxes...So they obviously block up...
Craig Thumbs Up
Post #113264 15th Mar 2012 10:12pm
SteveMFr
Site Sponsor
It is not worth reusing them after a rebuild - especially the TD6 (GM) trans cooler as the transmission usually lets go with a huge shower of internal shards. The particulates left in the cooler are so fine you can not flush them out completely. Risking a GBP2000 rebuild over an additional GBP300... Most manufacturers recommend similar: Porsche recommends the same thing for the engine oil cooler when a motor has popped.
If it is the ZF (VCool cooler that has stopped up it's a different story. If the cooler can be cleared with a flush - I'd do it.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #113269 15th Mar 2012 10:51pm
simonmanx
so where can i get one at a fair price ??
Post #113276 15th Mar 2012 11:35pm
SteveMFr
Site Sponsor
Unfortunately I believe it's only available as an OEM part.
LR calls for both lines and cooler to be replaced.
Give Dan a shout (Duckworths - site sponsor).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #113291 16th Mar 2012 8:42am
