Home > Technical (L322) > Wheel alignment done.....still problems |
You need the 4 wheels aligned, sounds like they have only aligned the front wheels which because the back axle is now out it throws the steering angle sensor out by more than 12 degrees and throws a fault |
4th Apr 2012 10:40am |
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 |
thats what was done initially hence why it was in at land rover yesterday for 4 hours on the 3d alignment machine getting all four wheels corrected |
4th Apr 2012 11:15am |
I would hazard a guess that whoever did it hadn't a clue what he was doing and the geometry will be well out hence the warnings popping up on the dash.
4th Apr 2012 1:55pm |
like i said before, it was mucked up first time round by a local garage. Yesterday is was in the Range Rover service centre having the geometry re-aligned on the 3d laser alignment machine. I have the report of the before and after measurements. They are now within Range Rover tolerances. The alarms were all up before I took it to range rover, hence why i just handed them 300 quid |
4th Apr 2012 2:20pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
You might need your steering angle sensors recalibrating to suit your new geometry. You sensors might have been up by the Indy who started the problem. Not a big job and would push LR to do that seeing as you have just spewed £300 in their direction. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Apr 2012 5:09pm |
It's not a £300 job to do a 4 wheel alignment, it should be around £60 maximum
4th Apr 2012 7:33pm |
+1 had mine done a few weeks back £80 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Apr 2012 7:56pm |
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 |
I would personally erase any historicial fault codes from the air suspension ecu, steering angle sensor and ABS ecu, if a fault code resides in any one of these three systems the symptoms you have mentioned will be generated.
23rd Apr 2012 4:35pm |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 |
Mine also had the rear bushes done a couple of months ago and the 4 wheel alignment was £60. That was at an indy. 2003 Range Rover HSE 3.0 TD6
23rd Apr 2012 9:20pm |
