Home > Wheels & Tyres > Been Looking at these
Do you Gents reckon they would take the weight of a FF ….
http://www.ebay.co.uk/itm/310378489637?ru=...l-Categori ====================================
Post #118342 19th Apr 2012 8:01pm
i wouldnt risk it mick, wrong size tyre as well.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #118343 19th Apr 2012 8:06pm
Not sure why you would but each to their own Whistle
Look like a cheap copy of the Style 7 RRS wheel - like this one
IMHO will look wrong on a FFRR
Post #118344 19th Apr 2012 8:08pm
paul r
Noooooooooo!!
Post #118345 19th Apr 2012 8:13pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Awe no, don't do it.. U shOuldnt mess with perfection. Thumbs Up
Post #118361 19th Apr 2012 9:34pm
Hell, it's your FF and not mine. Mr. Green
You'd get an increase in gearing with those taller tyres.
You need a Photoshop'd image before parting with your teetotal Whisky vouchers. Si. <This is my name.
Post #118387 20th Apr 2012 6:43am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
NO NO NO YUK. Shocked Dont think tyres are rated high enough weight wise either
Gary
Post #118457 20th Apr 2012 4:36pm
duckworthparts
Site Sponsor
could affect warranty claims aswell You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #118458 20th Apr 2012 4:51pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Those wheels are seriously tacky, don't do it. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #118621 22nd Apr 2012 1:18am
mzplcg
If you were seriously considering it Mick you need to ask about the load rating of the wheel (not tyre) and if memory serves, FFRR ones are 925 KG each. SSRR ones are 925 KG and D3 are 940 KG. Anything you buy must meet or exceed this.
Then there's the tyres. Load rated at 107 (975 KG) is not enough for a FFRR which needs 109 (1030 KG) or insurance will be void in the event of a crash. Sod the warranty, safety is much more important.
Last is offset. 45mm is less than the 52mm on a standard FFRR rim, BUT, I can't see any mention of rim width. Assuming it's a 9.5 (a-la SSRR) then the wheel moves in by 7mm and the outside edge protrudes about 19mm more. Might cause clearance issues over the brake caliper. Needs checked carefully.
So, still wanna do it? Nah, thought not mate. Thumbs Up
Dom
Oh, BTW.............
Those taller tyres are actually shorter, by 5% of the width. Standard FFRR tyres are 255/55/19, whereas SSRR uses the 255/50/19 quoted, the middle number being the wall height as a percentage of the tyre width. So you'd get shorter gearing.
The 20" tyres on VSE and S/C models uses the 255/50 size, as a 20" tyre, so 255/50/20.
Post #118623 22nd Apr 2012 8:54am
Opinions noted guys Thumbs Up , just as well I was only looking ... Thumbs Up .. So looks like your knowledge is correct once again Dom .... Thumbs Up
The search continues .... Laughing ====================================
Post #118625 22nd Apr 2012 9:52am
Here is mine when i had 22" wheels in that style fitted...
Most people liked them (customer feedback)
Craig Thumbs Up
Post #118626 22nd Apr 2012 10:16am
fisha
Correct me if i'm wrong ...
To an extent, the load rating of a tyre is a bit of a mis-used/understood figure ( cant think of the best workding ). As I understand it, its not necessarily the maximum load the tyre could take, but maximum load the tyre can take when running at its maximum speed. Its as this point that the tyre goes through the most amount of flexing and heating up. At slower speeds, there a bit more of an overhead in reality.
Then you have what the car actually weighs versus its theoretical max weight.
Thats not to say that I advise overloading tyres, just that its worth knowing what the numbers represent. V8 or else ...
Post #118663 22nd Apr 2012 7:08pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
i like them. original design is great but so are some of the designs made aftermarket. just depends which one you pick however they are very nice and as craig has shown they suit the car.
Post #118664 22nd Apr 2012 7:09pm
mzplcg
OK, this subject has been well covered on Disco3, mainly because of D3 and RRS interchangeability, except that the RRS runs on 109 load index and the D3 needs 111.
There have been a number of cases of blowouts when greenlaning on RRS tyres with a D3. Do a search and you'll find them. These are not just sidewall blowouts either, there are photos of huge holes in the tread area.
There is only one way with tyres. ALWAYS use tyres with a load index of AT LEAST that quoted by the manufacturer of the vehicle. Using under-rated tyres will invalidate insurance, and if you get an astute rozzer who actually does know the difference between his ar5e and his elbow, it'll cost you 3 points (and up to £2500 in fines) for each tyre which is contravening the construction and use regs. A tyre doesn't have to be bald to be illegal !!
Post #118674 22nd Apr 2012 7:53pm
