Home > Technical (L322) > clonk from suspension |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 |
stevenA
3rd May 2012 8:57am |
Don't get too excited!
9th May 2012 11:17am |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
I've just removed my front drop links to see if they are causing the knocking (both new OEM parts in last 6 months) they're both fine & have no play. I went for a drive without the anti-roll bar drop-links and it's still knocking, so that rules out the anti roll bar and drop links. Question is do they have a right way up? Just something else to check while it's in bits Range Rover 4.4 V8 Vogue |
11th May 2012 5:55pm |
Another frustrating day.
21st May 2012 10:12am |
New Landrover inner trackrod end fitted, still knocking.
25th May 2012 11:58am |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
I've just given up trying to solve this on mine ... turn the radio up loud enough and you don't hear it anymore ...
25th May 2012 1:01pm |
Thanks David will try that.
25th May 2012 2:17pm |
I would have thought it would have been blatantly bleedin' obvious by now I have NO CLUE where it is coming from!
25th May 2012 2:27pm |
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 |
I had a knock from the front suspension start a few months back.
26th May 2012 8:01pm |
Mine still knocks! Range Rover 4.4 V8 Vogue |
20th Aug 2013 10:59pm |
Mine too.
27th Aug 2013 11:31am |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 369 |
mine still does NOT clunk (or clonk) since i followed the advise of stevena of loosening and tightening all suspension bolts with the Rangies wheels on the ground. |
28th Aug 2013 7:49pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 830 |
Mine is beginning to really me off now! I'm still getting a knock/ creak when turning right. It comes from near side And had an obviously failed lower arm. I also changed the ball joint but still it makes the noise!
28th Aug 2013 10:33pm |
Hunttheshunt Member Since: 02 Oct 2012 Location: Hants Posts: 92 |
Currently in Charente Maritime and I also have a clonky front suspension. However, what seems worse is that when steering slightly right there is a vibration that has started to get worse, feels like it is part of the right front suspension, assume its a bush or track rod end. Any ideas?? Have 600 miles to drive back before I can get it checked :0( |
29th Aug 2013 11:27pm |
