Home > General > How much body roll is normal in corners? |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
I do find the FFRR rolls a bit more than my old 300TDi Disco which in turn rolled more than my 110 County V8. But I find it more reminiscent of the Rover P6 V8 and Fiat 130 V6 that I used to own, when cornering in those you would lean the car over and they would corner very well but with ridiculous body roll.
29th Jun 2012 11:18pm |
Yes they do roll, great fun if you are the driver but not the passenger |
29th Jun 2012 11:20pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
Cross-linked air suspension only works when the vehicle determines it is "off road".
The vehicle determines "cornering, heavy accelation or heavy braking" based on a sensor in the center console. If that sensor is faulty, it may cause problems. This sensor also feeds the DSC system, which will selectively brake individual wheels and/or reduce engine power to help reduce unstable conditions in turns. I haven't owned a "car" for more than 15 years; I don't even remember what it feels like to drive something with a center of gravity closer to the ground than 4 feet... Jim 2000 NAS HSE 2005 NAS HSE |
30th Jun 2012 1:55am |
farrellelion Member Since: 05 Jul 2011 Location: Oliveira do Hospital Posts: 22 |
I was unhappy with the rolling of my 2002 FF on first usage.But now, I find that I easily loose those suppositories up my tailpipe.I find it a well balanced vehicle, but you must corner in MANUAL MODE . Change down, and accelerate hard through the corner-- a Porsche mechanic once told me he loved the 911's behavior in a corner - don't be afraid, if you are in the correct gear(only possible in manual), the more you crap yourself, the harder you stand on the gas. I'm amazed at the cornering ability of this TD 6 .This is aided by good tires and there's no wallowing effect. In automatic however, you shouldn't be going at speeds that cause much roll, the ride is definitely on the soft side. 2002 Vogue TD6
2nd Jul 2012 11:51pm |
Just get an S/C, they corner quite nicely MY 2010 5.0 SC Galway green and sand interior!!
3rd Jul 2012 9:22am |
^^^ Sideways |
3rd Jul 2012 9:25am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
if you do decide to purchase this fullfat then consider investing in steve's IIDTool which will allows you to lower the suspension so that it handles better around corners..member DMRR has done this ... ... - .- -.
RenoHuskerDu Member Since: 27 Jun 2012 Location: Alsace Posts: 31 |
Is there truly a difference in the suspension of supercharged models? Reno, on assignment in France. |
3rd Jul 2012 11:19am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
S/C has stiffened anti rollbars, the same has been achieved on my TDV8 with a 15mm lowering all round. I would say my TDV8 handles better now than my previous 5.0SC and 4.2SC. Land Rover Addict
3rd Jul 2012 11:28am |
http://www.rangerovers.net/modelspecs/L322/2006.html
"Less publicized was the fact that as a result, wheel travel on the Supercharged model was reduced form 10.75 to 7.5 inches at the front, and 13 to 11 inches at the rear."
3rd Jul 2012 11:36am |
Caused by stiffened anti-roll bars Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
3rd Jul 2012 11:43am |
I can't compare the two as I have never driven a RRS (been in one but that is different). The S/C is very fast for a heavy lump and handles much much better than I am used of big heavy cars (Toyota Landcruiser, GMC Vandura etc.). I personally don't care about reduced suspension travel as I don't need it with my S/C.
3rd Jul 2012 11:44am |
Strictly speaking, unless the A/R bars are structural links in the suspension geometry or something along those lines, then stiffening them should have no effect on wheel travel at all. Unless of course you hold one wheel in a fixed position and measure only the travel on the other side but that would be python-esque parody now wouldn't it. As our yank friends would say: just sayin' - not trying to pick nits. But seriously, if there is less travel, then it's not just A/R bars that they tweaked. Now I'm curious. Reno, on assignment in France. |
3rd Jul 2012 12:26pm |
