Home > Wheels & Tyres > Advice please on wheel change |
You should have 255/60/18 as standard
10th Jul 2012 11:40am |
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 |
Hi thanks for the speedy response, would you go for the 19, 20 or stick with the 18 inch. Any ideas why I would have 265 tyres on my car and not the standard 255?
10th Jul 2012 12:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34921 |
i had those on mine elena, i think LR brought a cheap batch of them during 2005/2006 ...
10th Jul 2012 12:15pm |
Hi Stan thanks for the advice, watching some 19 inch ones on eBay. Does the spare have to be the same size wheel etc.
10th Jul 2012 12:40pm |
the spare doesnt have to be the same but its desirable for it to be... ... - .- -.
10th Jul 2012 12:46pm |
19s are a good upgrade for the TD6 without making for too harsh a ride, also a bit less tyrewall reduces the cornering roll effect
10th Jul 2012 1:25pm |
Hi, thanks for your advice just bought a set of 19 inch wheels with tyres. Do I need to have the suspension settings set to anything other than normal before changing the wheels please, may be a silly question but thought I should ask it, cheers. |
10th Jul 2012 3:03pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Hi Elena
10th Jul 2012 3:23pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
10th Jul 2012 4:25pm |
enumbers Member Since: 12 Dec 2011 Location: South east Posts: 26 |
Stan why is there a vibration issue on the td6 with the 20s on 2004 td6 Adriatic Blue |
10th Jul 2012 9:32pm |
Don't know the reason for the vibration with 20s on the TD6, but LR do not recommend fitting them. |
10th Jul 2012 9:34pm |
@enumbers, its the change in inertia and stiffness of the wheels allows a torsional resonance through the driveline from the engine firing pulses... ... - .- -.
10th Jul 2012 10:06pm |
Cheers for the explanation its crazy that the reduction in flex in the tyre wall would cause a noticeable effect 2004 td6 Adriatic Blue |
11th Jul 2012 8:53pm |
