Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 3 of 48 <123 4 ... 464748>
Just to prove to myself I wasn't going mad, I've checked, and rechecked and checked again, and I don't have the "Key in ignition warning if door is opened" as documented below.
Also I notice that I have options to change the %age of light that the main beam DRLs work at, which isn't mentioned below?
Any reason mine should be different?
LCM-LIGHT CONTROL
Daytime Running Light ( High Beam, Main Beam or None )
Follow me home with reverse lamp
FMH Front fog lamps
FMH Front position lamps
FMH High beam headlamps
FMH License plate light
FMH Low beam headlights
FMH Rear position lamps
FMH Reverse lamp (LCM Coding Index 11 only)
FMH Style
Follow Me Home ( FMH ) cancel with lighting switch
Front fog lights off if main beam on
Handbrake turns off Daytime Running Lamps
Main beam dim with DRL
Time in seconds for Follow Me Home ( FMH ) Got - 2017 SDV8 Autobiography in Loire Blue
Post #131072 14th Jul 2012 5:01pm
SteveMFr
Site Sponsor
Hi Alan,
The key bong eliminator was added after a request by Cam Tech Craig. So you'll need to update your IIDTool again. You
can delete the IIDTool updater files and program (uninstall) from your PC and then follow the original procedure to update your IIDTool again. The only difference will be that the updater will pop up a box staing that you already have v2.17 and if you'd still like to update to the same version.
Cheers!
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #131237 15th Jul 2012 5:55pm
Thanks Steve, I'll do that and give it a go!
Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #131240 15th Jul 2012 6:02pm
daveo
ok, i have been looking at the IIDTOOL, I have the rover com unit from RSW and dont get me wrong its great but its not moving along as quick as i would like it to, still waiting for the LCM programming to come along as well as the rain sensor settings,
now does the IID TOOL connect to your laptop as well,i have seen it used as a stand alone unit V8 facelift Range Rover Autobiography 22" wheels.
Post #131242 15th Jul 2012 6:08pm
the IIDTool only connects to the laptop/pc when new firmware is needed dave...stick in the obd port and the settings are adjusted from the cruise controls on the steering wheel... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131253 15th Jul 2012 7:40pm
SteveMFr wrote:
Hi Alan,
Cheers!
Steve
Thank you Steve, i did'nt even realise you have done it... Ill get on it now sir...
Craig Thumbs Up Thumbs Up Thumbs Up
Post #131257 15th Jul 2012 7:56pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The key bong used to really pi55 me off - IID Tool has made it magically disappear Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #131283 15th Jul 2012 10:32pm
tbh i didnt realise how annoying it was until i dis-abled it. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131311 16th Jul 2012 8:50am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I am trying to update my soft ware but when I press the Find Device button it says it can not find it although the laptop has already said it has found new hardware. Any suggestions from you more computer literates would be good thanks.
Keith 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #131449 16th Jul 2012 6:06pm
reboot the laptop and try again.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131460 16th Jul 2012 7:14pm
drakes
Still no luck. It bongs when I plug it in but does not show up as connected in "my computer" and the firmware updater says its not there. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #131465 16th Jul 2012 7:59pm
by coincidence i had this with my iphone today..try different a cable, re-install the gap downloader..all the kind of things that might be causing your problem..
last thought , does the unit work on the range? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131481 16th Jul 2012 8:45pm
drakes
I have tried a different cable and reloading the software, perhaps its time for an email to Gap. The unit works fine on the vehicle 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #131511 16th Jul 2012 9:54pm
unlikely it would be the unit if it works on the range...can you try another laptop/pc.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131545 17th Jul 2012 9:10am
update on mine,
alarm chirp now working due to a replacement alarm module being fitted...any way of increasing the volume of the chirp steve?
still cant access the drl menu. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #131596 17th Jul 2012 1:21pm
