Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
My current theory is that the Magna engineers will have specified ‘proper’ bearings for their transfer box but then their procurement people found some nice cheap ones from Slovakia, and these are not up to the task. This theory is based on a sample of one and I may well be proved wrong on this! I still find it interesting that Magna have chosen to axially preload this input bearing (with two disc springs/Belleville washers) - makes you wonder if they saw issues with this bearing during development?
18th Jul 2012 3:17pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Pm sent Phil |
31st Jul 2012 9:42pm |
I’ve never tried removing one of these transfer boxes myself. From the workshop manual it appears pretty straightforward but it looks as though the top four bolts are a pain to access and Land Rover recommend a special tool (wrench adaptor) :
31st Jul 2012 11:16pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Makes great reading
1st Aug 2012 4:01pm |
I’ve finally got around to dismantling the combined centre differential & low range reduction epicyclic assembly.
5th Aug 2012 5:29pm |
An excellent write up Phil.
5th Aug 2012 5:33pm |
gruodiz Member Since: 09 Dec 2011 Location: LT Posts: 10 |
Very interesting, informative write up Phil. I really like to read this one and ZF 6HP26 write ups.
4th Aug 2013 8:57pm |
RRDEL Member Since: 11 Mar 2014 Location: USA Posts: 1 |
I have the same transfer case with a stretched chain (like the old ones).
11th Mar 2014 9:27pm |
I believe that Cobra Transmission (Miami) stock the chains
11th Mar 2014 10:38pm |
Hi phil,
10th May 2014 9:04am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I'm on my third seal too - mine turned out to be a crack in the casing.
13th May 2014 10:42pm |
Hi Phil.
14th May 2014 2:50pm |
bump |
20th May 2014 4:53pm |
Yes I have, though I’m struggling to find the information again. It may have been from a Discovery or RR Sport bulletin board because they use the same transfer box. I definitely recall seeing photos of cracked/porous transfer box casings and they’d been like that since new. I’ll see if I can find it again.
21st May 2014 11:50pm |
