Home > Maintenance & Mods (L322) > ZF 5HP24 Auto Fluids |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I've done some searching and could find the answer to this, if there is one, so here goes:
12th Aug 2012 7:30am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1261 |
Budgie, I think it was this link I got it from...
12th Aug 2012 9:30am |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 |
this is when u need someone who is going to do theres to go halfs with u and split the cost of the fluid |
12th Aug 2012 9:55am |
Thanks Fisha,
12th Aug 2012 4:32pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Liqui Moly 1200 is compatible with the Lifeguard5.
16th Oct 2013 6:08am |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 |
when i rang my local west london dealership in regards to having the gear oil and filter changed their exact word was,if the gearbox is not giving you any grief then the oil and filter should not be changed below 150,000 miles.. |
16th Oct 2013 7:23am |
Well I just dropped the pan and filter today on my 02/03 Vogue V8.
16th Oct 2013 10:39am |
Saltyfish Member Since: 19 Jun 2012 Location: Yate/Bristol Posts: 22 |
I recently changed the oil in my Rangie, after speaking to a guy from "Miller oils" i decided to use oil from them as recommended on their web site. I changed the filter at the same time and can confirm after appx 1000 miles i have had no issues, infact after changing there was a noticeable differance in gear changes, they are a lot smoother. This mileage also includes towing my heavy caravan to and from Cornwall.
17th Oct 2013 2:23am |
What volume of fluid did you collect when you drained the trans?
17th Oct 2013 5:17am |
