Home > Technical (L322) > Rear Wiper |
Just recently the water jet from the rear window has stopped, but the rear wiper motor is still working but no water , have tried putting a fine needle into the hole of the jet in case it was bunged up with dirt , on doing this small droplets of water start coming thru , but when i go to use the rear wiper -- Nothing no jet of water ..........
17th Nov 2008 10:56am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
This happened with mine after I bought it, would take ten wipes of the screen before any water came out.
17th Nov 2008 11:42am |
To open the tailgate and try what you said i think i will need to wait untill late May 09, as there might be a possibilty of a dry day up here in Sconnie Botland
17th Nov 2008 12:20pm |
I know that the top tailgate always drips water when you open it (and normally it all pours just inside the lower tailgate ) but you'd be able to tell if there was more water than normal.
17th Nov 2008 12:27pm |
Pump works fine, no overspill water on the top of the tailgate, no damp spots within the boot area......... |
17th Nov 2008 7:00pm |
if you can gain access to the pipes, try disconnecting the pipe from the nozzle and seeing if water comes out. Then you know it's the nozzle at fault (obviously!)
17th Nov 2008 7:49pm |
It might not be 'normal' but at least you're getting plenty of water out, mine takes 2 washes to get clean these days. Discovery 4 HSE
19th Nov 2008 12:52pm |
jpr Member Since: 12 Aug 2008 Location: North East Posts: 63 |
mine stopped completely recently so took it into LR and they said they get at least 4 or 5 of these a week, they then basically cleared the pipe with an airjet and all done! ---------------------------------------------
20th Nov 2008 10:55am |
Soupdragon Member Since: 24 May 2008 Location: Norfolk Posts: 57 |
Mine has exactly the same problem; hardly anything comes out at all. Perhaps RRs develop some sort of prostate problem, after all, they are a male car! Rules are made for the obedience of fools and the guidance of wise men. |
22nd Nov 2008 7:47pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3696 |
have you tried the squeeze and hold method |
24th Nov 2008 12:51pm |
I haven't but my wife has sometimes when I've been late home from the pub! Rules are made for the obedience of fools and the guidance of wise men. |
24th Nov 2008 9:38pm |
