Home > Technical (L322) > Fitting Telestart Heater control |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 |
Hi Everyone
13th Oct 2012 8:05pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
plug and play |
14th Oct 2012 8:22am |
When I fit the unit will I also get the aux heater displayed as it only shows aux ventilation at the moment? My car is a 2002 vogue Thanks Gary |
14th Oct 2012 12:51pm |
no you need to program the aux heater |
14th Oct 2012 1:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7649 |
This is exactly where I'm at............have a Td6 with FBH, but only Aux Ventilation available on the menu, no Aux Heat............
14th Oct 2012 1:57pm |
Managed to buy a Telestart & remote but i will be if i can find the connectors? - the repair manual says they are on the drivers side rear but can not locate the plugs.
19th Oct 2012 7:36pm |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 |
I second that think i may have found cabling clipped to front of fuse board but no aerial |
21st Oct 2012 5:14pm |
Hi Noddy
21st Oct 2012 8:17pm |
Hi Gary,
24th Oct 2012 11:48am |
Hi Steve
24th Oct 2012 4:52pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
HAve you got it working yet? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
12th Dec 2012 9:43pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Hello Gents. My name is Paul and I own an L322 VSE TDV8 on a 57 plate that has the Aux Heater fitted.
27th Nov 2013 4:37pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Hi Paul
28th Nov 2013 6:30am |
Thanks Axle.
28th Nov 2013 11:02am |
UPDATE- Axle....did what you said and its working a treat...many thanks! - Paul |
29th Nov 2013 11:48am |
