Home > General > Re starting my search for an RR, thinking of a 4.4 V8 petrol |
Nogbag Member Since: 19 Mar 2012 Location: North West Posts: 29 |
I look forward to reading the replies because I too am looking out for a similar spec / age/ mileage. If mileage is not going to be huge I would'nt hesitate with petrol although if you are towing maybe diesel would suit better. I'm sure somebody out there will enlighten us. |
30th Oct 2012 11:08pm |
Lots to find using search on V8's |
31st Oct 2012 12:37am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
I've got a 2002 V8 with LPG and now on 104K miles.
31st Oct 2012 7:21pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3070 |
Steptoe, that's 20p per mile or 31 MPG equivalent at £1.37 per petrol liter. that's good!!
31st Oct 2012 7:49pm |
double entry - bloody accountants!! |
31st Oct 2012 7:51pm |
Restless Member Since: 04 Apr 2012 Location: UK Posts: 36 |
How do you find it runs on LPG?, I've read conflicting things about it, some say the BMW 4.4 runs fautlessly on it and others say there are issues with the ECU and under fueling, from what I understand they are usually pretty ok with Prins and BRC conversions so would go for one that had either of those conversions or really for the mileage I will be doing just go for a petrol one, I'm not very keen on a TD6, they are more to buy and have things that are more likely to fail on them-Gearbox,Injectors etc. |
31st Oct 2012 10:33pm |
can't tell the difference between lpg and petrol except when i really boot it and it switches to petrol but then i am due a LPg service this week and that should sort it out. it is only when the tank is low on lpg. |
1st Nov 2012 2:05am |
It's a Prins system, installed in 2009 by previous owner. Has since covered nearly 40K miles, and it's been faultless since i've had the car, and the previous owner also said the same. Kept the full sized petrol tank and fitted a 92Ltr kitre gas tank in the spare well space. So when both are full the range is huge. Absolutely no noticable difference when switching between petrol and gas. Plus cheaper road tax because it's registered as duel fuel vehicle |
1st Nov 2012 2:39pm |
Thanks for the info on the LPG ones, I think as they don't really hold much premium over a normal V8 I might as well try and buy one tht has already been converted, they definately seem a better, cheaper bet than a TD6. |
1st Nov 2012 5:43pm |
May have a cheap 2003 soon...... |
1st Nov 2012 6:02pm |
Thanks, please let me know if it does come in . |
1st Nov 2012 11:42pm |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 |
hi restless.i am biased but go for the v8.you are going to do 5k miles a year so if lpg version costs alot more to buy,i cant see much saving.my advice is go for condition and history if miles are high.good luck 05`V8 AUTOBIOGRAPHY |
2nd Nov 2012 6:34pm |
