Home > Maintenance & Mods (L322) > Need your suggestions - EAS! |
Reservoir Pressure static on filling - this means that although the pump is running it doesn't register an increase in pressure.
31st Mar 2010 1:29pm |
Stebo Member Since: 14 Sep 2009 Location: Northern Ireland Posts: 39 |
The speed was always quite slow - maybe take a minute from access to off-road (assuming the tank is empty). Goes up and down immediatly when the tank is filled.
31st Mar 2010 1:39pm |
Seems one needs to replace the reservoir as well as the switch, I imagine you can buy pressure switches online if you can find out the exact type though?
Hmmmm: http://www.epvl.co.uk/pressure_switches/PMN.html |
31st Mar 2010 1:58pm |
Thanks for that.
31st Mar 2010 2:49pm |
Was out at the car seeing if rising the car with everything turned off and a constant 1.8k revs (to keep a good current) would make any differance and have discovered the following.
31st Mar 2010 3:47pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
My money is on the compressor, its worn to the point its not pumping.
31st Mar 2010 5:25pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
do all the lights go out on the controle panel and no adjustment possible
31st Mar 2010 10:44pm |
The lights on the pannel all stay on, with the dot on the button to stop movement illuminated. If I try to change height the light just flashed a couple of times. UPDATE - had a bit of a futter with the airsuspension on the battery charger again last night. Messed with it for the guts of 15minutes and couldn't get a fault code to pop up. With the tanks completely empty the car was able to raise up to full height (just on the compressor) in about 40 seconds which I didn't think was too bad. Haven't had a fault code pop up on my commute this morning either (which I am thinking is maybe because the battery will be 100% after the charge last night). This, to me, points towards a tired battery. But then again maybe the compressor is close to it's end and was only working well due to the increased power (ie more the would be possible from a battery alone) it was getting from the charger. I also discovered that there was a problem with early cars randomly throwing up the "pressure static while filling" fault due to the EAS ECU firmware and that an update has been released which solves the problem. Unfortunatly the stealers want £90 just to check out what version of the firmware the ECU is running . I have a new battery lined up (£100), a compressor (£175), and the option of getting raped by the dealers (£90). What one do I take the gamble on first Is there any way to test what condition a battery is in?? |
2nd Apr 2010 8:41am |
there is a way to check your battery but in my experience they are not very reliable i had mine checked and told there was nothing wrong with it. however it still went flat in hours or just would not hold a charge in this case the gobby at kwick fit was wrong, new bty fitted no probs since
2nd Apr 2010 10:49am |
Problem is that getting it diagnosed will cost as much as trying both new compressor and battery.
2nd Apr 2010 11:25am |
Is the price for the compressor a one off I will be looking to sort my compressor once I recover from having the injectors reconditioned.
2nd Apr 2010 11:51am |
Compressor price is from a low milage, recently hit Range Rover at the breakers. I've never done the "service tweek" but I've a fair idea how it works. |
2nd Apr 2010 12:20pm |
