Home > Technical (L322) > Fuel Pump In the tank TD6
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Has anyone had the diesel tank fuel pump fail, if so what were the symptoms , im having trouble with a fuel injection system fault and my indie thinks this is the problem, Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #165431 17th Jan 2013 4:33pm
Had mine go! Sad
Basically it would struggle to rev over 2000rpm an cut out if i tried to put a decent amount of power down as display a fault.
The pump has just had enough and wasn't able to provide the secondary enough which would then suck air in as well which was fine for light throttle as the air would self bleed out through the system but when power was needed it would suck the air in to Sad
If you look in my previous posts I replaced the outside tank pump first as I thought it was this and it didn't fix it Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #165449 17th Jan 2013 5:26pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I understand that it is a nightmare to do, fingers crossed for you. My external one went six months ago, and luckily the tank one was ok. The mechanic (specialist with Land Rovers) said the tank one is usually very reliable as it only works to balance the fuel across the tank. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #165450 17th Jan 2013 5:27pm
m90got
Thanks for help lads fingers x this works beginning to wish I had never bought it !! Current Stable:
Post #165456 17th Jan 2013 6:17pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
hi you can do two tests
1 electric, if there are problems at the pump with a tool or similar tool should alert you iid error
2 mechanics, with a pressure gauge to check the flow rate of the pump (bar)
Post #165495 17th Jan 2013 8:29pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Flashman wrote:
I understand that it is a nightmare to do,.
The tank is quite easy to access. Removing the back seat is about the hardest bit as it is so damn heavy, but after that, fairly straight forward. There are inspection covers in the floor, remove these then there is an inspection plate on one side of the tank, and the plumbing and electrics in the plate on the other side. Undo the plug and hose clamps, then slide the hoses of the barbs - this is a bit fiddly, but once off, the plate, pipes and pump come straight out. The pump is then easy to change on the bench.
If you have a few basic tools and a couple of hours, give it a go. Thumbs Up
Cheers - Gav.
Post #165653 18th Jan 2013 12:09pm
Prop
I had my in tank fuel pump replaced on my TD6 just before xmas.
My symptoms were fuel injection error followed shortly by the engine cutting out. This would only happen when it got down to between quarter and a third of a tank of diesel left. Funny thing is the car would restart after a couple of minutes of letting the pumps prime and get me to the nearest fuel station to fill up. I also noticed that a couple of times when it was low on fuel that the car would struggle to start before I got the fuel injection error and engine stopping. but the car ran perfectly if I kept the fuel tank above a third of a tank.
I was lucky and got a nearly new pump off the bay for just over £60. When the car went in to have the pump changed I took a look in the tank as it was down to about a third of a tank, the side the pump fits on (Drivers side) was pretty much empty, while the passenger side of the saddle tank was full to the brim. The inside of the tank was totally spotless so I know there was no contaminants. It was just the siphon part of the pump was not moving fuel across to the drivers side part of the saddle tank. Anyhow it took just over an hour to fit and since then I have run it to under 20 miles range left and its been fine.
Post #165791 18th Jan 2013 10:17pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I had rough running and would not rev over around 1800rpm and assumed it was an injector or fuel pump, but it turned out to be the fuel injector wiring loom that had failed (independent loom that just plugs into the rest of the electrical circuit). Turned out to be a relatively cheap part in the end @£58 + vat if I recall which didn't seem bad for the item I was getting. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #165831 19th Jan 2013 2:35am
ahebron
New Zealand
Hmmm, I wonder if this is what is up with mine.
Mine goes into limp mode when going around a particular lefthand uphill corner with power on. If I feather the throttle then it kicks back in and all good.
Adrian VW Amarok 2014 Highline auto
Post #165833 19th Jan 2013 7:48am
RRVSE
When my loom failed , I got no warning messages at all, the car just ran very rough (I was about 20 miles into a 60mile trip home when it happened so I nursed it home). Steve
Post #165881 19th Jan 2013 1:05pm
