Home > Maintenance & Mods (L322) > 4.4 V8 PCV valve replacement...by Deasy |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34948 |
please post your comments on an excellent how to by Deasy here....
9th Feb 2013 7:39pm |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
Cheers guys
10th Feb 2013 11:17am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Good write up. The inside of your intake plenum is hanging! I found I had very little in mine but then again I think mine was still working just replaced out of caution. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
10th Feb 2013 12:39pm |
Yea I know, it's abit of a mess. I haven't got the time to strip it down n clean it out though.
10th Feb 2013 2:09pm |
I guess it should be ok. The PCV is the important bit and that's new now. The cyclone is clean so slowly should do what it's designed for an the plenum should clean up. You could always take the throttle body end off and give it a clean up with some rags if you were that concerned. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
10th Feb 2013 5:06pm |
