![]() | Home > Technical (L322) > Select Neutral? |
philrover Member Since: 17 Jan 2010 Location: Manila Philippines Posts: 13 ![]() ![]() |
In the past couples of days, each time i start the car i get a message saying "select neutral", then the moment i drive off it will say "slow down". Then it goes away. Im thinking this message appears when the engine is running hot, but my temp is dead center and no signs of overheating. What could be causing this? BTW this is a 2003 FFRR 4.4V8. 06 FFRR HSE
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
On my 2006, you get this message when you have flicked the "low range" switch - it's asking you to select neutral and then it will switch into low range for you. If you flick the "low range" switch again, the message goes away ... |
same here, i get that message when in low range, the neutral part is you have to select it to switch between low and high range, V8 facelift Range Rover Autobiography 22" wheels.
Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
I have exactly the same behaviour since I unplugged all fuses (to locate battery drain) a few days ago.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Normally means the hi low motor is defective! £1350+vat ouch!!! |
Can fuse removal provoque this issue (I mean killing the motor). 2008 TDV8 VOGUE - Buckingham Blue on Sand |
That's spoilt a few Sunday evenings. ![]() |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
There is a thread on here somewhere about replacing the rheostat / circular resistor component within the tranfer motor. It was not a part that was available through land rover, but a member was getting some manufactured and was planning to sell them at a fraction of the quoted price for the full motor. I do not know the outcome, but it could be worth doing some digging to find the thread and see if he ever did get some manufactured. MY2010 TDV8 Vogue Ipanema Sand
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
No still not manufactured/available, but apparently still coming..... .
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
From reading a bunch of threads on this subject, it seems a regular cycle between Hi and Low ratio is a good habit to get into - IIRC the problem with the rheostat is corrosion/fusing due to lack of movement! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Mine did this when turning a left hand corner as one of the abs sensors was bust , the difference in wheel speedsmade the car think something was up and would try put thebox into low range.the new abs sensor cured it. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 744 ![]() ![]() |
Do you mean one of these? Could be a good buy |
