Home > Maintenance & Mods (L322) > door mirror |
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 |
please could any body tell me how to remove the rear of the door mirrors as i want to check the bulbs under them as neither of them seem to work cheers |
14th May 2010 8:20am |
cheers does the mirror glass just pop of |
14th May 2010 3:17pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
yes it does, it requires a reasonable amount of force. It is a thick unit so don't be too afraid... having said that as with all Range Rover parts they are expensive. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
14th May 2010 3:24pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Do what I did, drive the car so close to a hedge it bangs the mirror glass out so its dangling on its wires Discovery 4 HSE
14th May 2010 4:19pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
while they are off upgrade them bulbs to the led ones, the ends of the led bulds must be under 12mm to fit through the bulb holder.. they make a big difference...
14th May 2010 5:13pm |
doublejay Member Since: 08 Nov 2009 Posts: 131 |
we're talking about the puddle lighting ? i have one gone too.... would be interested if anyone fits a LED. It does look kind of flash when you lock to the car. |
17th May 2010 12:56pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 830 |
Anyone know how to remove the 2007 ones? Theyre a different lens, does that just pop off?? |
7th Jul 2010 6:39pm |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 57 |
I need to replace one of mine too, I need to pluck up courage to prize the mirror off!! |
22nd Jul 2010 11:02am |
You don't have too! You can poke a screwdriver under the mirror glass and release the clip. Towards the outside edge of the mirror there is an access hole, if you poke a small screwdriver into that and lever, it will release the oust clip that allows the lamp to drop down.
22nd Jul 2010 8:55pm |
