Home > In Car Electronics (L322) > Satnav red cross
Page 2 of 4 <1234>
try '753' ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #182670 13th Apr 2013 8:51am
mackempete
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Out of curiosity I checked the GPS info screen while in the under ground car park at work. Still lists satellites with their positions. Can only assume that satellite ids andtheir Geo stationary position is in the software and isn't picked up from the aerial.
Post #182779 13th Apr 2013 5:52pm
A1GSS
Cached positions from the last time it saw them? GPS signal won't reliably make it through a concrete underground carpark... Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #182780 13th Apr 2013 5:53pm
super8
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Aerial on order....
Thanks Stan - 753 Code worked... zero signal so put it down to the aerial... new one on order, by the power of ebay... will report back. Range Rover - Supercharged - On the drive.
Discovery V8 - Sadly gone.
Post #182803 13th Apr 2013 9:03pm
Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #182804 13th Apr 2013 9:11pm
Paul J.
Same happened to me. Used the 753 hack to show that there was no signal. Antenna replaced and all is good.
Paul.
(Was very impressed with the dead reckoning ability of the satnav unit when the GPS was offline)
Post #182812 13th Apr 2013 11:45pm
mackempete
Where did you get your antenna from Paul? I've pm'd duckworths but not heard anything back yet.
Post #182823 14th Apr 2013 7:20am
Paul J.
Had it done at the local main dealer, ISTR about £200-250 fitted, possibly less.
Paul
Post #182926 14th Apr 2013 8:40pm
Johnte
Antenna is around £50, fitting is pretty straight forward Thumbs Up
Post #182930 14th Apr 2013 9:08pm
super8
Problem Solved... how it happened
I have now resolved my SatNav GPS red cross... and here's how.
First off this needs some minor trim removal, 10mm Spanner and precision screwdriver set with star bits. Along with some very basic crimp requirements.
Ebay GPS unit for sub £8.00
http://www.ebay.co.uk/itm/GPS-antenna-FAKR...3f1a262923
1. Remove the rear plastic pillars that house the rear speakers.
2. Pull the roof trim down, there is a central clip so mild force is needed.
3. Once you have the roof lining down, you will be able to access the bolts that hold the aerial casing in place.
4. You need to remove both bolts, to be able to remove the casing that contains the GPS unit.
5. Once the two bolts are removed the metal plate will come free.
6. You can now push the aerial casing free of the roof, although you will need to squeeze two small clips that retain the casing where the cables go into the aerial casing, within the roof lining.
7. Once you can access the aerial casing, undo the series of screws on the unit.
8. This reveals two antenna, the one to the rear is the TMS and the smaller unit is the GPS.
9. You can now either remove the faulty GPS or simply place your new unit over it.
10. Some very basic cable tracing back to the join within the roof lining allows you to connect your new GPS unit... although you will need to remove the connector that is attached and re join as it needs to pass through the aerial casing.
11. Put it all together.
12. Check your GPS and all should be good.
This was easier than expected, once I had realised I didn't need to take all the trim off the side area that houses the DVD / Sat Nav etc...
This isn't the easiest job as you need to be able to get good access on to the rood of the car and reach a fair way into the roof lining, so I guess it might not be for everyone.
Any questions, just shout. Range Rover - Supercharged - On the drive.
Post #186055 1st May 2013 7:04pm
mackempete
Thanks for this super8.
I followed your guide and i now have working GPS. Thumbs Up
I took pictures while i was doing it so if you dont mind I'll pad out your instructions with some photos for other people.
Cheers
Post #188070 13th May 2013 5:59pm
so its all down to a failed gps antenna, glad you two got it sorted.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #188071 13th May 2013 6:02pm
A1GSS
Thumbs Up Same symptoms as my Audi, similar fix. Graham
____
Post #188149 13th May 2013 10:34pm
mackempete
Yip. There was no obvious damage or water ingress to my antenna. Nor could i see any obvious damage to the cable\connectors. TBH as the replacement was only 8 quid i didnt look too hard Smile
Post #188154 13th May 2013 11:03pm
jackomcfc39
England 2008 Range Rover Vogue TDV8 Santorini Black
Did you get this sorted? as Im having the same problem richard
Post #188405 15th May 2013 10:36am
Page 2 of 4 <1234>
